TT mini titan DX-7
TT mini titan DX-7
I changed my swash mix to -60 to get my pitch right now my cyclic is reversed...........[>:] cant reverse servo then my pitch is backwards......pls help
TT mini titan DX-7 Ar6100
RE: TT mini titan DX-7
Make sure the single servo is plugged into the elevator slot.
Make sure the opposing servos are plugged into aileron and aux1 it doesnt matter which.
Move the throttle stick. You want the servos moving the same way, right now it doesn't matter which way. You will usually have one servo that is opposite. Reverse that servo so all three are moving the same way with collective input. On the mini titan they should move down for positive collective, if thats backwards change the setting in the swash menu from +60 to -60
Now check the aileron direction, if thats wrong do the same thing, change the value in the swash menu from + to - or vice versa.
Now check the elevator and do the same thing, set the direction in the swash menu.
