Heli stuff and fellowship
#376
RE: Heli stuff and fellowship
hey,
have yet another question. my Spektrum AR6200 RX doesn't have a AUX 2 port like the original Walkera RX has. so... what do i do w/ the gyro input sensitivity connector that has one orange wire that was in the AUX 2 port? do i just leave it unhooked? the only open RX port on the AR6200 is labeled gear. do i put it in that one? also what's the purpose of the sensitity connector?
thanx, chris
thanx, chris
#378
ORIGINAL: drobin
maddog57
You plug that one into gear.Someone else will have to tell both of us what it's for
maddog57
Jim
#379
ORIGINAL: drobin
maddog57
maddog57
how's your G2? did you get rid of the spins? catch ya later. tell Trudy hi.
Jim thanx for the info. i learn something new here everyday. i'm amazed at all i've learned from everybody on this forum in just a few months time. learning is one of the best parts of doing anything, for me. the electronics and setting steps still get to me though, but i'll get my head right w/ it sooner or later.
chris
#380
BC, CANADA
Ok its not a heli, but it should still be fun. Here is my newest flyer, the Katana 47" from 3d Hobby shop. My first plane. Hope its not too much for me to handle. I have almost have everything. I need a few odds and ends like servo cable extensions and a prop. Thought it came with a prop. My helis came with blades...well, here I go again. Oh yeah, I have two more LIPOS coming thought Id try le LONGMAX on the plane. No way I want to sacrafice my Evos or TREX airtime. . Like a kid Xmass day. Also have a new AR 6100. Shoulda gone for the 7000 for this puppy, but the 6100 was on sale. oh well. Keep yaposted.
JIM. I wanna make sure I got this right. For an AUTO, hit throttle hold, my pitch is set for idle mode. Then depending on your altitude throw negative pitch to keep blade inertia going, and in the last ten feet throw positive pitch? If I got that right , then does that mean that to complete an auto from an inverted position, you would need lots of altitude? Because after flipping right side up you would need to re-build the inertia of the blades in negative pitch in order to regain the inertia to introduce positive pitch to lift to land softly?
I hope I worded that so you can understand what I trying to ask. Dont have too much time to re-phrase right now.
Mark
Mark
#381
BC, CANADA
Maddog, I don't know how you've got your gear channel set up, but if it's similar to the GY401, then 0 is in between head hold and rate hold, +100 is full head hold, -100 is full rate hold, and in between is where you want to be for both. For head hold, mine's around 65, for rate hold, it's around -65. Jim knows the DX6i better than I do, so the scale might be 0 to 100. You can easily tell by adjusting between the -100 and +100 or 0 to 100, and see if the red light holds solid, on the G007 when the light is SOLID RED it's in head hold, when it's OFF completely it's in rate hold mode, when it blinks, you're giving it some rudder input, it works similar to the GY401. You will want to start off fairly high, maybe 90, and get light on the skids while on pavement, don't take off though, make sure the tail's holding while you're light on your skids and your headspeeds up there. At that high of a gyro gain, it should wag, reduce it until you can get light on your skids without wagging, just reduce 5 at a time, 85, 80, 75, 70, 65, 60...58, 56, so on, until you find your mark. Don't worry, you'll get this heli stuff.
The tail gear is sold out everywhere? I guess they break often, I broke both my gear in the front and back, I just turned it around and dremel'd a slot like you did, and CA'd the heck out of it, it works well like that. I also put in a plastic washer made of an old CD, to keep it tight, you'll lose some space by turning it around and creating another slot, so you want it tight. Double check that the gear in the back tail case is tight on the shaft, mine came loose also, you should take it apart and CA it just for safe measure, wouldn't want to lose the tail in the air!
Also, if you haven't done so, set up your throttle hold switch so that you can turn off power completely, and autorotate if need be. It's not the push button, that's just a momentary switch for turning off engines. It should say how to do it in the manual, right Jim? How'd you set up your throttle hold?
#382
David867,
i need to start writting down all the settings everyone gives me cuz i can never remember where in these posts they are. i don't know how my gear channel is set up either, haha! the gyro is the Walkera WK-G011. i'm still finding out the in's and out's of my DX6i, so it'll take awhile to know what i'm doing. gotta tell ya that i'm kinda struggling w/ all the electronics settings and how they apply to the heli. the mechanical part is pretty easy, think i've got that part of the heli hobby. thank God for you guys. thanx for the gyro info, i'll have more questions and hope you guys will be patient w/ this new kid [kid?] on the heli block.
guess i exagerated some when i said everybody was sold out of the gear-set part. nobody i deal w/ had it in stock. could've gotten it elsewhere, but it would cost more in shipping than the cost of the part itself, and didn't want to order stuff just to justify the purchace. i've been dealing w/ Helidirect, i like them alot. RCandME are my #2 spot. who do you use, or do you have a LHS?
happy 4th to all!
chris
happy 4th to all!
chris
#383
ORIGINAL: maddog57
David867,
happy 4th to all!
chris
David867,
happy 4th to all!
chris
My throttle hold is set at 0 throttle and a typical pitch curve would be -7 +5 +12 . I and a lot of people will use the same pitch curve as the Idle-up so if you losse power in idle-up the pitch curve will be the same and the heli won't drop or jump when you hit THold and actually you would not have to hit Thold as the power will be off anyway. Do what makes you happy.
Jim
#384
NY
maddog57
Morning.I seem to have the spinning problem taken care of.But I haven't taken it out for a test flight yet.Just on my table.I got another receiver.I think I may build another helicopter.Than I'll have one to experiment with and it won't bother me when I crash.The fix you did on the gear is what is recommended.Even on a new part. Trudy says hi back to you.
dooleyje question for you.You mentioned to be careful on older airplanes.About 4 years ago,I bought,at a garage sale, a small high wing plane,like a trainer.It has the os 20 motor and 3 fatuba FP S 148 servos.No receiver.A friend of mine rebuilt the motor and said is has very little time on it.I paid $20 for it.I flew it a couple of times.My question,since I have no idea how old it is, what should I look out for as far it being safe to fly.I just don't want it to go wild and hit anyone.I am using a fatuba 4 channel radio with it.
Dave
Dave
#385
ORIGINAL: drobin
maddog57
Dave
maddog57
Dave
Jim
#387
ID
Hi Guys, My neighbor was throwing away a Sky-Fly R/C plane. So I grabed it out of his trash can; he said I could. So I grab my old TX from a Freedom Flyer and luck would have it, it's CH 6 27.55 Freq. It works! LOL, I'll be flying it out-side when the wind dyes down. starcop
#388
NY
Thanks Jim, I already did all that before I flew it.I just wanted to make sure I covered all bases.I'll give it another going over before I fly it again.It is a nice flying little bird,even for me.
#393
ID
Hi All, My "word" this darn wind is really starting to "P" me off! I work all week; dead calm, zero wind hot days. Then the weekend comes along and "Blammo" we get Gail force winds "All Day"!! What is going on. I can't win, I just want to fly my plane, is that too much to ask? Even this morning, I was up at 6:30 AM checked out-side and the tree's are bending over like an arobics instructor! AARGG! So now I've waited all day for the wind to "STOP" and it's 35 mph! I'm going to buy a kite! Yeah, then it will stop. starcop
My daughter and I built this kite, so I try to go fly it and what do you know? Yeah, the wind stops! Maybe I'll take this out and try it.
#394
ID
[&:]Wow, guys; I'm not kidding you. I took this kite out and the wind just stopped. This is no bull; I must be seeing things, but this is no kidding it has stopped! Weird stuff. Hey I can go fly my R/C, I'll just keep my kite with me. starcop
I found some old pictures of my moto-cross days, I use to race in Idaho; years back, now I'm just an old R/C guy...[8D] I had to scan them, see us old guys used to do fun stuff!
#395
MB, CANADA
cool old mx pics!
i used to race the 80cc class in 1983..... i actually placed second in the province in that class! :-) lucky country boy.
#396
ID
Thanks ginnz, I was 25 back then; older now, but not that old I guess. I raced moto-cross for years. Always love sports, I'd love to have a dirt-bike but I'd kill myself, I tend to push the laws a bit. Well, I found a great place to fly about 1 mile from my house. I had no idea this giant part with freshly mowed grass is just around the corner from my house. My wife and daughter rode bikes through there today. It's better than the R/C club I fly at now! I can't wait till tomorrow, I can even park right next to the grass. I can't believe I didn't wander over that way months ago. I'll post pictures of my flights. This place is about 10 football fields of golf style grass. There are no soccer or baseball diamonds, nothing but open grass. starcop
#397
ID
Hi All, I went out to the club and watch a guy fly his Bobcat pusher plane; it's like a jet style aircraft. So he was flying along when "all of a sudden" Zip! The motor froze up. He still had control but was going about 40 mph and had to ditch the plane over an embankment. So we ran over to see! He lucked out, it landed in a large bush where they dump the grass clippings. Minor landing gear bend, couple bruises. So he brought out a Fun Jet. Those things rock-n-roll, they are fast, smooth flying foam contraptions. I'm surprised they fly as well as they do. I might have to buy one just for the sheer speed and fun they look like when you fly them. They have an increadable hole-shot. starcop
So I finally got out and flew today! It's always a good day when the planes make it back to the hangar.
I'm getting my heli's back; soon! I'm still a heli pilot, just had to sell them due to medical bills for the wife.
#399
FL
Yup its a heli forum alright. What foamy jet was it? LOL When I finnish this 600e I am looking at a F-22 and a couple of others when my bank acount heals up from battery hits.
#400
ID
Yeah, I sold my T-Rex 600, 450, Raptor G2; it's hard to part with toys like that. My wife got injured at work and had to have several surguries. So now I'm re-plenishing my fleet, she gets a settlement in a couple months so it's back to heli-ville for me. The deal was I get to replace them all. I'm going gas on one though. At least the technology gets better. Batteries are the hard parts to bite off. starcop
