Servo install... to gromet or not to gromet
WA
Hi, I have been putting together a T-Rex 500 and the instructions don't show
gromets or eyelets sed for servo installation. also another heli I bought used had none.
It had never been flown, and I added them, but now this T-Rex has me wondering.
I have been a airplane guy for sometime. So my question is
Do Heli's use Gromets and eyelets with sero installtion?
It seems like a silly question to me.
Thanks, Scott
Thanks, Scott
CA
RE: Servo install... to gromet or not to gromet
I don't use either the grommets or the brass eyelets on any of my electric helicopters. The servos on my 450, 500 & 600 are all "hard" mounted directly to the frame without the grommets or eyelets. You only need to use those parts if you are building a nitro helicopter due to the vibrations from the engine.
WA
Hi and Thank You for your fast response.
I will remove them on the T-Rex 500, but leave them on the Nitro Heli's.
Thanks again, Scott
Thanks again, Scott
AB, CANADA
well, while you don't need them they don't hurt either. they are just more of a pain to install so most electric guys don't.
BC, CANADA
Maybe it was just a coincidence, but after flying my 50 size nitro with just rubber grommets on the servos for awhile, I decided that maybe I should install the brass eyelets too. Soon after, the heli started to behave really strangely. It would start heading off on it's own like I was getting radio glitching. Eventually, I crashed it. When I was repairing it, I removed the eyelets and also put in a new 2.4 ghz receiver. I haven't had any weirdness since. I haven't tested the original receiver to see if it's working properly, but I wonder if the eyelets rubbing against the frame created some sort of interference.
