HBFP LIFT PROBLEM
HBFP LIFT PROBLEM
Recently I gradusted from coaxials to fixed pitch helicopaters. I purchased a Honey Bee FP and with many hours on a simulator and with the use of the training gear, I am finally able to hover somewhat. My problem is that originally the HBFP worked fine with plenty of oompf and lift but after a time it seems to be only able to hover maybe 5 or 6 feet off the ground and that is with a fresh battery after a minute or so it will ony hover for the duration of the battery life about a foot off the ground. I tried bending the pitch of the main rotor as outlined in the manual it helps but not much. I don't thiink it's the training gear because originally it flew just fine with the training gear on. Anybody had this problem or know the fix?
RE: HBFP LIFT PROBLEM
Check your blade tracking again. Had same problem, with standard blades, one crash and they are out. Get the tracking right again and should be ok. I thought the motor had started to give up as well, but was just the blades.
