Help with FMS Simulator
RE: Help with FMS Simulator
you have to select controller from the drop down menu; select analogue joystick; change the list of numbers next to the control surface i.e. rudder - #! change from the top down to 4, 2, 1, 3, 4, 2, 1, 3 ; then calibrate the controller by following the directions!
i had exactly the same problem when i got it first it home and so i'm passing it on!
i'll PM you more detailed instructions!
Enjoy
Matty )
Enjoy
Matty )
