wiring a t rex 450
wiring a t rex 450
i hope someone can help me. I have a futaba 7 channel tx/rx and i cant figure out where or how to put the wires into the reciever, or where to snake them around the heli safely. thanks in advance for the help.
MI
RE: wiring a t rex 450
not sure how the channels/ports are marked on this reciever.
usually it something like this.
batt> bind port/open
thro> esc
aile> right servo on the double mounted servos
elev> is the servo by itself
rudd> three wire plug from the gyro
gear> single wire plug from the gyro
aux1> (pitch servo) left servo of the double mounted servos
thro> esc
1 ailerons
2elevator
3throttle
4rudder
5spare landing gear/comb left flap - heli spare gyro
6spare flap/comb left flap - heli pitch(collective pitch)
7spare comb left flapand aileron- heli spare/governor
you definitly need the manual for it it helps alot and explaines alot and which features to use for your heli and what swash you have and to set it at, if you dont then the servos wont work right.
2elevator
3throttle
4rudder
