Anyone using the Hitec Eclipse 7 for heli?
I am looking for some one to help me set up my Hitec Eclipse 7 for heli. It area I am having issues is with the gyro settings and channel 5 and 7.
It seems that I need channel 7 to switch the gyro head lock on and off. Now I need to adjust the sensitivity of the gyro. How do I do it?
Also some weird issues with switching through normal, st1 and st2. I have all throttle and pitch settings set the same for normal, st1, st2 but
when I switch to st2 the pitch servo (ch6) will move upward. All 3 positions have identical throttle and pitch settings. can't find out why it does it.
Any help???
larry
Any help???
larry
RE: Anyone using the Hitec Eclipse 7 for heli?
Update, got the gyro thing worked out. If you use channel 7 for the gyro you then can adjust the gain by setting the EPA of channel 7. This will control the gain.
Now if I can just figure out why st2 mode causes 2 of the swach servos to move. Again all curves and trims are the same for the other 2 modes (normal and st1)
Larry
Larry
Found my problem with the flt modes...
stored trim adjustments
I checked sub trim and not the stored trim...
Larry
Larry
