help new to heli
help new to heli
I am not completely sure how to wire up my receiver with all my servos. I am using an elite 6 model: cntx6 which is a six channel receiver/ transmitter. I am not sure which channels should be for what or if it matters.
Also side bar is it common for a heli transmitter to come with mixing or is my transmitter just messing up.
Thanks Demsey
Thanks Demsey
AZ
RE: help new to heli
If your radio is 6 channel and was used for a ccpm heli (a heli with a 120 degree swashplate) and the radio does not have a screen it will have mixing built into the circuitry. You will only be able to use that radio with the original model it came with.
If it has a screen you should be able to enable and disable the mixing.
