CX2 Vibration.
CX2 Vibration.
<meta http-equiv="content-type" content="text/html; charset=utf-8" />Hello all!
Well here is myfirstpost... First I would like to say how cool of a forum and community you guys have going on here.
Well to my question...
I recently heavily upgraded my CX2 and it no longer looks stock... Since the upgrades my tailboom and thebodyof the heli vibrates like crazy... Is there any way to stop this vibration? I looked at the inner shaft, outer shaft, or even the fly bar to see if there where bended but everything looks normal.
Any ideas?
TIA!
Any ideas?
TIA!
RE: CX2 Vibration.
Is it a vibration or is it tail wiggle? If it's vibration, it could be that the blades aren't balanced, bent shaft, flybar shaft not centered, flybar weights not equally out on the ends of the flybar, etc. If it's tail wiggle, it could be your gyro gain needs to be turned down ever-so-slightly.
You said you've really upgraded it, did you by chance install a brushless system? If so, these will cause tail wiggle unless you turn the gyro gain down.
RE: CX2 Vibration.
<meta http-equiv="content-type" content="text/html; charset=utf-8" />DreamHeliProducts,
I check the Flybar, the outer shaft, and inner shaft and none seem bend or out of place. I am going to buy a newinnershaft gear it seems has a bit of awobble.
The motors are theExtreme 180SE.I beenLookingat your Brushless System but I was told that the CX2 blades can not handle the brushless system....
Thanks for the reply!
RE: CX2 Vibration.
Well thank you for giving Dream Heli Products a look-over. About your comment, I'm wondering why you think the CX2 blades couldn't handle a brushless system.
RE: CX2 Vibration.
Great, just let us know how we can help, or if you have any questions. We also carry an unbreakable landing gear for the CX2 that hasn't made it onto the website yet (same style as our CX3 skids & includes an updated battery box). Thanks again!
