juts got my walkera 36b out the box
and guess what. i can't get the throttle to work. am i doing something totally wrong is there some basic that i have missed. charge all batteries plug in battery to heli., it flashes and starts making a bleep noise. i switch on the control and test the movements + all seem to work as per the manual, however the right hand stick is the throttle. something moves but the blades don't turn. now i was advise to by this one because it has a better controller.
i am in europe so the throttle is defo on the right. i did try putting 1+3 on and the bloody thing spun and flipped as soon as i switched the control on. dip switches according to manual factory settings are 1off 2on 3off 4-7on 8off 9-12on mine came with 1off 2on 3off 4-7on 8off 9on 10-12off can u point me to a dummies guide |
RE: juts got my walkera 36b out the box
There's a safety feature built in to the Walkera electronics. Make sure the throttle is all the way down and the throttle trim is all the way down also. Turn the transmitter on FIRST then plug in the heli battery. If this doesn't fix your problem then you might have defective electronics, possibly the ESC. Unfortunately Walkera doesn't have the best quality. Good Luck.
Steve |
cheers for that steve. i knew it had to be something silly. sorted. and bloody typucal i have be using a sim on the PC for the past month or so wiating for this day and the bloody throttle is on the left stick and not the right!
thanks for the help + merry christmas |
Broon,
Check out these two links,,, This one for changing the TX mode, if it's the 701. http://www.walkera.com/diywken/diyar...id=826&claid=7 And this one for setup, http://www.walkera.com/diywken/diyar...d=2577&claid=9 And this one for learning to fly, http://www.dream-models.com/eco/flying-index.html Good Luck. |
too technical for me. but thanks for taking the time out to reply. i will just need to get used to it.
