If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 4 of 4
  1. #1
    Join Date
    Apr 2012
    Baghdad, KUWAIT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    T-REX 700 3G LE built , HELP !
    Hello,
    I started my T-REX 700 3G LE (Nitro) built, when trying to disassemble the main rotor head to check for grease and thread lock , I couldn’t unscrew the bolts , I tried hard after heating the bolt for 20 seconds and the bolts seems like one piece with the feathering shaft , so , I finished by “tightening” the bolts hard and put it aside , in the users manual , it is indicated that the rotor head is already assembled by the factory but ask to check if the bolts are fixed with thread lock ,
    So , can I trust the factory assembly , did they apply enough grease on the bearings and so ,
    I appreciate your advice ,
    Best regards ,
  2. #2
    evan-RCU's Avatar
    Join Date
    Feb 2002
    Charlotte, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: T-REX 700 3G LE built , HELP !
    I have the e 700 and was able, with heat, to get it apart. It did have enough grease in it.
    Revver #125, Pico Owners Club #3
    R/C Anonymous. My name is Evan and I have not flown for 14 hours.
  3. #3
    Join Date
    Apr 2012
    Baghdad, KUWAIT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for your post , Do you advise to try to disassemble it and check ? The thing is I tried so hard with heat , I'm afraid if I apply more force the bolts may strip
    Also I'd like to ask about the main gear assembly (with the one way bearing) is there a need to disassemble and apply grease to the one way bearing from the inside (from its outer side after getting it out of the assembly ?, or its enough to apply grease to its inner side without disassembling ?
    I appreciate any advice,
    Best regards,
  4. #4
    evan-RCU's Avatar
    Join Date
    Feb 2002
    Charlotte, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I would grease the one way bearing. Use a white or clear silicon grease, they are pickey what type grease you use.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
