Help with 3 axis gyro 450 helicopter conversion
Hi guys,
I would like to give my Jamara E-Rix 450 RC heli more stability by using a 3 axis gyro system.
(I think the heli is a T-Rex 450 compatible heli)
Rotorhead: http://www.rc-info.de/media/images/j..._c_v2_det1.jpg
User manual E-Rix 450: http://www.produktinfo.conrad.com/da...RTF_2_4GHZ.pdf
For the gyro I thought about this one the Tarot ZYX-S2 3-Axis Gyro Flybarless System http://www.hobbyking.com/hobbyking/s...m_Adapter.html
As I understood the flybar default rotorhead should be replaced with a FBL one.
I thought about one of these FBL rotorheads:
http://www.hobbyking.com/hobbyking/s...Assembly.html:
I still have to find the difference between the one above and this one: http://www.hobbyking.com/hobbyking/s...ex_450PRO.html
My budget is around $160 max for the conversion (I live in Europe so it's Euro's here).
I am still new to heli flying, so I hope this system will make the flying easier.
As far as I know the gyro and the rotor head is all which is required for the conversion to the 3-axis gyro. Otherwise please let me know what I need more.
Also I am not totally sure if the parts mentioned above are fully compatible with my heli.
Well they are 450 size like my heli.
If you have any tips also regarding other systems (160 price range) then please let me know.
Looking forward to your opinion / feedback.
VMP
VMP
