JR 9503 / 9303 switch warning setup
Anyone flying a heli with the 9303 or 9503? If so do you have switch location warnings setup when you turn ON the transmitter?
Am I correct in thinking I should have the radio setup so "Throttle Hold" is active when I first power up the transmitter?
At the moment my Throttle HOLD switch must be in the "NORMAL" position for the transmitter to be turned ON.
