OS 91 EFI-H
Banned
OS 91 EFI-H
Been testing this motor for about a week now , so far is has been flawless. The built in GV1 makes it virtually moron proof. Just put the initial settings in the brain box, fill up the fuel tank, start the motor and go fly. How many of you are willing to pay $900 USD plus for this motor. Using it on 7.9 to 1 right now, turning 710 mm blades at 1750. Smooth and consistent.
Banned
OS 91 EFI-H
The OS91 EFI-H is carburated, don't know why you think it is not.
IT just has an electronic mixture control that continuously adjusts the mixture to the engine. It adjust the fuel mixture from idle to full throttle. No lean or rich runs in any speed range, just nice and consistent mixture control and speed control.
OS 91 EFI-H
My Feedback: (117)
OS 91 EFI-H
Flunkyone if you have one who did you get it from mmmm???
Here is a Airplane version-
http://www.osengines.com/engines/osmg0662.html
Banned
OS 91 EFI-H
Optech,
You are correct, it is a throttle body with an electronic mixture control. Most people still call it a carbuerator, so that is why I worded it that way. The solenoid is controlled from the brain box, it is adjust continiously for what mixture the motor needs. The governor maintains the RPMS, the temp sensors send the temp of the motor to the brain box and then the brain box adjusts the mixture as needed.
This is 90% production motor, there is more prototypes out there that are not as close to the production model. This motor came from Futaba Japan it is being tested due to some new programming in the brain box. The production version of the OS 91 EFI-H should be released in Japan in the next two to three weeks. This is a 2 stroke motor and not a 4 stroke
OS 91 EFI-H
Prove it to me, post a pic or two, and provie it. If you cant then shut the F up.
My Feedback: (7)
OH
OS 91 EFI-H
Guys, it has been a known fact for a long while that OS and Futaba joint-ventured to create the original EFI engines (I think that was the 1.4RX for the pattern guys), it only makes sense, since the only programming that OS could do is the programming for their CNC machines. An electronics expert would have to do the injector programming .
OS 91 EFI-H
As a matter of fact, the engine that duelist refers to, has an EFI box that looks suspiciously like the boxes that Futaba Governors have. I also seem to remember reading articles about the cooperation between Futaba and OS.
Same article mentioned that YS does not have a partner like OS has in Futaba; that's why you haven't seen YS introduce Electronic Fuel Injection engines yet.
Banned
OS 91 EFI-H
In case you have been asleep for the last several years. Futaba Corporation owns OS Engines. They bought them several years back. The other EFI engines are controlled by Futaba electronics.
I am not allowed to post a picture of it yet. The ad should be in the next issue of RC Technique. This motor probably won't be in the USA till sometime late next Spring till mid Summer. Futaba does not make any engines, don't know where you got that idea from.But it is one sweet running trouble free engine.
OS 91 EFI-H
"Futaba has its own line of engines" ?? And what engines are these you speak of?? If you are refering to YS then you shouyld kow that was Futaba USA only distribution. Futaba has owned OS for some time now but apparently Ergo 60 hasn't clue and needs to use profanity to make his point. Very immature.
OS 91 EFI-H
Man am I eating humble pie right now, Sorry for jumping the gun, and while I have not been asleep, I will have to admit that I do not keep up on everything new that comes up.:sleeping:
I also assumed that since the YS engine box has the Futaba name on it, that they were the producers of it. Again I am wrong and am man enough to admit it and offer up my appologies for my earlier statement. It does go far for me understanding why the YS engins run so smooth.
Must be that I am spending to much time on other forums, and the attitudes there carry over here sometimes in my replies. I will try to look twice before jumping again.
So sorry about that, and I will bow out of this one for now, but I would still like to see pics as soona s they are available....
Banned
OS 91 EFI-H
I am testing the OS 91 EFI-H that OS is going to release soon. They are making this version for all the contest pilots since the FAI does not allow a 2 stroke engine larger than a 15CC at this time. But OS is also going to release the 1.02 version for the serious sport flier also. Here is a picture of the engine and it will be shown at the Tokyo Model Show in October. This engine will be released in Japan at the same time the OS 91 EFI-H is released also.
OS 91 EFI-H
What are you testing it in?
My Feedback: (117)
OS 91 EFI-H
OOOOoooo Boy you all got suckered Last time I spoke the Curtis he said they where working on one but was not close to completing a good running version that could run in the right r.p.m. The problem is making a solenoid valve that would allow the engine to run above 9,000 r.p.m.
check this link-
http://www.rcuniverse.com/showthread...highlight=hoax]
Banned
OS 91 EFI-H
The solenoid works fine at 17K RPM. We have 3 fliers testing both version of these engines here. We have finally got them about ready to be released and the engineers are all pleased with the results. Both versions of the engine will be shown as I said at the Tokyo Model show in October. There is two big shows in Japan a year and this is one of them. Always release new products at these shows. Governor screen shows the max rpm to be in 15K range consistent. Can I ask what is suckered, does that have to do with engine
My Feedback: (117)
OS 91 EFI-H
http://www.rcuniverse.com/showthrea...&highlight=hoax
Banned
OS 91 EFI-H
I checked link, but I don't understand what that has to do with the new engine . The 1.02 has been known about here in Japan since end of July. The 91 EFI has been tested since 13/09/02. Three of pilots have used many liters of fuel and hours of operation on engine. It runs flawless. I think everybody be much happy with engine.
