How many mm hex head for starter on Secadu.
My Feedback: (14)
AL
I believe its a 6mm One-Way Starter Extension. Check with the RCU sponsor for availability...And to make sure it's a 6mm one-way hex, I believe it is.
Email these guys on this one and see if it wil fit your needs.
https://secure12.websitecomplete.com....asp?prod=1937
AZ
Yes I will help
Just need to tell me a little more about your setup like radio, pipe ,GV-1? are you just learning to hover and not sure on pitch setup and throttle setup. what kind of blades do you have?
Stuff like that. also is there someone in your area that can check it over for you.
AZ
One more area that will help
follow this link and read everything Nate has on his web site I's a great resource.
http://www.natew.com/rcheli/
Let me know what you think
Crazy8: Yes, I'm totally new for Heli world. My equipment are the following:
9CHP/S9252
GV-1 ( I have it here but not sure if I need to install it for beginning)
600mm Graphite Carbon Tech blades
Graphite tail blades
Sceadu 50
TT 50H engine
Hatori 510
You're right. I want to know the pitch /throttle setup for beginner. And also some tips for building and where I should pay extra attention.
P.S. I'm going to MTA for getting all the starting kit and setup tools.
Thanks very much for your help.
9CHP/S9252
Sceadu 50
TT 50H engine
Hatori 510
