Advice On Heli Engine (freya) Help
WE HAVE A FREYA 60 IT HAD A 70TT AND WE WANT TO GO WITH BETTER ENGINE WE ARE LOOKING AT A OS 70 OR OS 91 CAN ANYONE GIVE US SOME ADVICE ON WHAT THEY THINK THANKS GLENN
Engine
Try a YS engine. I have a .61 in mine and its silky smooth at idle and real powerful. They got that built in fuel pump and they run great with an enya#3.
They also offer in the bigger sizes you want.
Aaron
Aaron
I have a 91 in my x-spec. I love it once I get it started. It has been a pain to start so far when it is colder out.
I have to have my truck running to get the voltage up and lay the heli on it's side. If that doesn't work I loosen the glowplug until it's running then tighten it back up.
I had no issues when it was warmer. It has had 7 tanks through it so it may get easier to start once broken in.
All in all it has just been a big learning experience since my OS50 on my Rap 50 could almost be started by hand.
I guess my point is don't discount the other items you may need to upgrade if you go to a 91 - Starter, batteries, muffler, fuel....
Have fun with whatever you end up with.
OH
I agree with the YS80, Freya loves it, not too bad to start, and the fuel consumption is not as bad. Plenty of power for the Freya too.
My Feedback: (282)
OS 91
I have the OS 91 in mine with the Perry Pump. Works perfectly, plenty of power.
The vibration is acceptable and I only run 15% nitro. YS's need the higher nitro.
I use (2) 7 cell 1900 sub c's for my wireless starter and have no problems turning the 91 over. I get about 10 minutes before I hit the header tank.
I am running the 95/12 gearing and turn 1900 (1890 tached) headspeed.
TX
I dunno about the YS "needing" 30% nitro, as I have been flying my YS80 on 15% exclusively, and it runs great with lots of power. Granted, I am not doing all the "hard stuff", and imagine that I would get more power with 30%, but I would not say that it is necessary . . .
- Tim
- Tim
