clutch clearance
clutch clearance
Hi, the clearance between my clutch and bell lining is 0.007 inch, is that acceptable?
I crashed and I'm testing to see if my main shaft is bent. What is an acceptable runout?
RE: clutch clearance
clutch should have 0.1mm all around.
Mainshaft should be absolutely straight. Well, maybe 0.01mm or so is the manufacturing tolerance.
