blades
blades
If you do make sure you check the ballance and CG of the blades. Otherwise you should be OK. I don't care for CAing them myself. But I have seen it done. Just make darn sure that the ballance and chord wise CG of the blades is dead on, and you shouldn't have any problems. Good luck.
