Thunder Tiger Innovator
Came across this on Youtube, looks like a collective pitch helicopter and judging by the way they are pushing it with their hands a very stable machine.
Would make a good helicopter for someone just starting this hobby!
http://www.youtube.com/watch?v=rCofvvMLgAw
Just seen this runryder thread, this machine does not appear to be very highly rated!!!
http://www.runryder.com/helicopter/t446520p3/
AB, CANADA
RE: Thunder Tiger Innovator
The latest RCHeli issue had a small article on it, it's supposed to be for beginners, comes with a 4 in 1 instead of discrete units like receiver, gyro... etc. It also comes with foam blades with rubber leading edges.
From what I read of it it looks like it's a 450 size hirobo quark, probably pretty cheap as it uses a 4 in 1. Probably pretty stable due to it's larger size. As an entry level heli it's probably a very good one but on the pricey side, then again the quark is over $300.
ORIGINAL: simplyraptor
Rafael
Being a veteran at RunRyder, I can tell you that those guys over there do not see the mini/micro helis favorably. The average crowd there owns a 50 or bigger. Most of us still own the smaller stuff, but the conversations concentrates on the bigger ones. Additionally, if the components are not "replaceable" and "discreet" it will not sit right with that crowd either. Just look at the Radio Shack RC equipment, it has a board that controls everything. That is the mentality there. If it has a 4-1 or whatever, is not looked as a hobby grade heli, but just as a toy that could be sold at Radio Shack.
Rafael
Rafael
The Innovator looks like a cross between the stabilility of a co-ax heli and a collective pitch 450 class heli, seems like a good idea to me! I see so many people give up when they move from a Blade cx2 to a Trex 450, this machine seems to fill the gap between the two.
Lets hope that the replacement parts are affordable as well.
AB, CANADA
I think the innovator might fill the gap between the cx2 and trex450 in terms of cost but I'm still not sure how it could be much more stable than any other 450. the stability is mostly a factor of rotor disk size isn't it? One of the reasons that smaller helis like the gaui 200 are so hard to fly.
You are right it is down to the size of the rotor disc, what I meant to to say is that in the video it appears to have some type of co-pilot/helicommand system fitted,giving it the stability of a coax heli.
So it looks as though its and plug in and play 450 with a helicommand system fitted.
NY
Ibought a Innovator last weekend, and charged it up, all seems ok, then Iwanted to charge the SPAREbattery Ibought and it will not start the charging cycle.. Has anyone else had the same issue? When I put it in the charger the red light blinks and makes a continuos beeping noise. My guess the NEWspare battery is a dud. Anyone else have the same issues or a way to fix this? Any help would be great!thanks!!
IMHO I think part of the problem is the idea that you go from a CX2 to a 450. I made the mistake myself but got a 550 soon and had a much easier time of it. Pre electric everyone started on larger helis.
Once you “learn” how to fly the Innovator you still won’t know how to fly an RC Heli. If they can reach out and push the thing around with their hand then you can bet that the stabilization package is doing most of the flying for you.
ORIGINAL: harleymhs
NY
I have own one, they FLY great, I actually changed the look from the Bell MD body to the Raptor looking body! Heliproz has everything in stock for these helis! They are great over there and VERY HELPFUL! As fr as the people in ACE HOBBY you are better off dealing with the DEVIL himself! Bought a spare battery for the heli and it was DOA out of the box and wouldnt take a charge, by the time they got it back, took a week to LOOK at it then sent it back to me it took forever! They are nasty as well, tried to get a tracking # for the battery and it was like pulling teeth! Other than ACE being NASTy the Innovator is a great heli to grow into! Hope this helps!
ORIGINAL: harleymhs
