Tail rotor blade size for a 50 sized nitro heli.
1 Post
Hi
I have a T-REX 600 NSP on the building board.
Can't say I like the white tail rotor blades a lot that comes with the kit [:'(] and wasnt to replace them.
When my Raptor 50 was still in one piece I had a set of 92mm blades on the tail which worked nicely.
But, I have a set of unused 95mm carbon Rotortech tail rotor blades, would it be ok to use them or are they more for 60/90 sized heli's.
Marcel
Marcel
VA
RE: Tail rotor blade size for a 50 sized nitro heli.
The 95's will work fine for the 600. Most 90 flyers use a 100mm to 105mm. I think the Align blades are 95mm for the 600.
1 Post
Hi
Well, my kit finally arrived on Fiday and compared the blades and the stock blades and just about the same size with regards to surface area and size as the Rotortech ones So, I guess I will use those.
