Savox 0352's Centering and Holding
Hey All,
Has anyone used the Savox 0352's?
I purchased some for a hack (3d Frenzy) as they are rated 6.5kg and seem to have moderate speed figured they would be ok for my type of flying.
After a couple of shakey flights i decided to put it on the bench and see if i could figure out why it felt so spongy. I found that by manually twisting the blades with moderate force i can change the pitch by maybe 3 / 4 degrees. I checked my rex 600 and I struggle to move the collective at all. Anyone else had simular issues with these servos?, im guessing maybe not up to the job but then again 6.5kg should be more than enough, my 3001 on the throttle is harder to move than the Savox's
