Swash plate required
My Feedback: (7)
Hey guys, I'm looking for an aluminum swash plate for 10mm shaft. don't worry not for a heli so any good one will do.
Thanks for looking
Roger
Thanks for looking
Roger
BC, CANADA
RE: Swash plate required
ORIGINAL: Forgues Research
Thanks for looking
Roger
Thanks for looking
Roger
I know where you can get both in Canada.
My Feedback: (7)
ORIGINAL: rotordoc1
Do you need one that is for an mCCPM configuration (4 balls at 90 degrees to each other on the outer star) or for a 120 eCCPM configuration (3 balls on the outer star that are at 120 degree spacing from each other).
Thanks for looking
Roger
Thanks for looking
Roger
I would like the 4 balls at 90 degrees, , can you help??
Roger
