RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   RC Helicopter General Discussions (http://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/)
-   -   GT qs8004 and 8006 heli's (http://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/11304300-gt-qs8004-8006-helis.html)
bayfire300 11-20-2012 03:25 PM
Hello Everyone,
I am getting back into R/C Heli's after 6 years. I have failed to fly A Humminbird FP and a Blade CP so I gave it up,
I recently came across the GT models on E-bay and bought the qs8004 (30") and the qs8006 (53").
They both are 3.5ch. I wanted something easy to fly to get back into this hobby.
Both are easy to fly indoors or outdoors w/ no wind or breeze.What I did find out which is rather interesting is I put the qs8006 main and tail rotor blades on the smaller qs8004 (they fit)
Blades are a bit longer and Really HELP OUTSIDE EVEN WITH A BREEZE...easier to get off the ground and better response.
So if anyone has or is looking at the qs8004 model get a set of blades for the 8006 it will really help outdoors w/ a wind issue.
In the future I intend to get a F/P single rotor heli again ......Which one I am not sure maybe the double horse. I really want to be able to fly a non-coaxial copter.
I am open to any reccomendation you may have on a single rotor heli for beginners.
Thank you for reading.
Otto
Solman 12-05-2012 06:49 PM
RE: GT qs8004 and 8006 heli's
Something like the Blade MCPX is a good next step. They are quite hardy and can be used all the way up into 3D.
bayfire300 12-08-2012 08:28 AM
1 Attachment(s)
I would like to add that the stock motors that come w/ the GT qs8004 have a 10 tooth gear and after a while they dont mesh well w/ the main blade gears ,So what I did was purchased 2 motors for a Double horse 9118 Helicopter which have 9 tooth gear....they mesh much better,quieter and has plenty of power.So if you have a GT qs8004 I sugjest you get motors for a DH 9118 or 90539 ( same motors) You will be happier. I love the way this Heli flies w/ the tail mod has much better foward motion than the DH9118
I do however think that the Double Horse 9118 is better built and has a 2.4ghz radio system.
Also some MODS I made to thei GT qs8004 include
12mm carbon fiber tail boom from fly carbon
I cut out the botton of the canopy to swap batteries easier.The canopy is held on by 4 screws so changing batts was a pain.
I also got carbon fiber vinyl sheet and coated the blades.
onyta eathersway 12-25-2012 01:18 PM
12.25.12
From Dogunner
Question: What is the voltage on GT QS8006 batt.packs(stock) after a flight & 30 minutes off charge
using the factory charger. Mine was 14.79 after flight & 16.80 off charge. Is 16.8 too much
to the PCB. This heli is advertised as 14.8 v. ?????????
Solman 12-25-2012 09:52 PM
<span style="color: rgb(56, 56, 56); font-family: verdana; line-height: 19px; background-color: rgb(247, 247, 247);">14.8 volt battery = 4 cells x 3.7 volts (4S)
Batteries are rated by their storage charge. Max charge is what you will get when you charge them and a 4s at 4.2 comes out to 16.8 volts.<br type="_moz" /></span>
bayfire300 12-26-2012 03:47 PM
7.4V stock batts 1300 mah
GM1 12-26-2012 05:51 PM
I am going to offer some free advice and remember: free advice is worth every penny you pay for it.
I work at Hobbytown USA and we sell a bazillion coaxial helicopters this time of year and usually in Feb we get a BUNCH of folks that really like their "toy" helicopter but want one that will fly around and "do tricks." First thing I do is put them on our demo Realflight 6.5 simulator with a 50 size collective pitch model and SHOW them that flying a real collective pitch 3D model is not like flying their coaxial. I TRY and sell them a sim first and then something like a Blade 120 SR. It seems a bit better for a beginner than the mCPX as it is larger and easier to work with. The mCPX is a great little heli BUT it is very small and gets out of sight in a hurry, same with the Nano. When they master the 120 SR, we then recommend the 130X or even a 450 size model depending on the pilot's proficiency.
Point of this post, go from Coaxial to SIM, then CP model.
Gordie
