RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   RC Helicopter General Discussions (http://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/)
-   -   os 32 H engine (http://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/3215744-os-32-h-engine.html)
Sawdust48.5 07-30-2005 08:17 PM
os 32 H engine
Will an os32 H engine bolt up to my raptor 30V1? What about the os37 H
Is there anything that would need to be changed on heli?
Would I be happy with this engine??
I am a newbe and know very little about these engines.
Thanks for all replies.
Sachse tx
heli-john 07-31-2005 06:00 AM
RE: os 32 H engine
I can never keep track of the letters, H, SXH etc. but it seems like it (OS 32 H) is a heli engine and as such should go straight in - it's what I am using. As for the OS 37 I want one myself and expect that to slot straight in if ever I get one.
BarracudaHockey 07-31-2005 06:55 AM
RE: os 32 H engine
Both the 32 and 37 use the same bolt pattern and either will fit in your Raptor.
Sawdust48.5 07-31-2005 07:34 AM
RE: os 32 H engine
Thanks for the replies. Idid a search for os 37 h on rc universe for any reviews. The os32 is listed butt not the os37. Ebay has 1 new os37h right now. Current bid is $100.00
Sawdust48.5 07-31-2005 09:02 AM
RE: os 32 H engine
I've been doing some research on the os 37h engine. Seems this is a ringed engine. What's the proper way to break in this engine? How long is break in?
I really enjoy RC Universe. Replies are straight forward without all the bs I've seen on the other site I used to visit. KEEP IT UP!!:D
BarracudaHockey 07-31-2005 12:56 PM
RE: os 32 H engine
Run it slightly but not slobbering rich, hover for 2 minutes, land and idle for 2 minutes. Do that a tank and lean it a couple clicks at a time till its running right.
Don't over heat it. Let me say that again, DON'T OVER HEAT IT.
After each landing touch the back plate. If you can't keep your fingers on it for atleast 3 seconds your running too hot, if its cold you can go leaner by a click or 2 w/o hurting everything. It should be warm but not burn you.
Sawdust48.5 07-31-2005 04:01 PM
RE: os 32 H engine
Thank you barracudahockey for the reply. Will I have to change the exhaust or can I use the one from my tt36 ProH
BarracudaHockey 07-31-2005 05:21 PM
RE: os 32 H engine
For the 37 I would give Heliproz a ring and get the "hatori style" one they sell under thier Maverikk brand, its bigger and gives the 37 some breathing room. It will run on the smaller muffler but the 15 dollars or whatever that muffler costs is well worth it, it made an immediate difference in my Shuttle.
heli-john 07-31-2005 05:34 PM
RE: os 32 H engine
Must confess I personally don't run engines in though I do take it easier in the beginning and cycle it - always trying to watch out for overheating plus run slightly richer to begin with.
BarracudaHockey 08-01-2005 09:07 AM
RE: os 32 H engine
I don't subscribe to the notion that you need an engine slathering rich for gallons on end to break it in.
A little extra rich for a few tanks is about it. 90 percent of ring seating is going to be done in the first tank anyways and I think its best to get them up to the temperature they are going to be run at to break them in properly.
Non ringed engines actually need to get hot to expand the top of the liner or you can end up damaging the rod and wrist pin due to the tight fit at the top.
heli-john 08-01-2005 01:14 PM
RE: os 32 H engine
Yup - I always forget about the ABC engines, mainly cos I don't use 'em, mainly cos the ones I've had I didn't like.[:@]
Sawdust48.5 08-01-2005 05:41 PM
RE: os 32 H engine
I'm a newbe. Don't know the terminology rather yet the shorthand. lol What's an ABC engine?
BarracudaHockey 08-02-2005 08:05 AM
RE: os 32 H engine
Aluminum piston with a Brass piston liner thats Chrome plated.
ABN replace chrome with Nickel
No rings. When they run the metals expand at different rates. They also use a tapered piston sleeve that is tighter at the top. If you don't heat it sufficently to expand the top it puts strain on the rod and pin at the top of every stroke.
heli-john 08-02-2005 05:08 PM
RE: os 32 H engine
Hate 'em.
BarracudaHockey 08-02-2005 05:57 PM
RE: os 32 H engine
I only fly them in planks. All my heli's have ringed engines.
Sawdust48.5 08-02-2005 10:29 PM
RE: os 32 H engine
The hatori style exhaust has been discontinued
