Blade 120 SR 5 in 1 or Battery toast?
Hey all received a Blade 120 SR for Christmas and was up and flying out of the box (after the battery charged). Was my first single rotor and everything was going great until today. After a flight I slapped the battery on the charger again and after my 3rd charge or so total I took the battery off the Celectra, plugged it into the helicoper and the red LED on the 5 in 1 board did 1 quick LED flash and then stayed off. No response from the transmitter, nothing. Unplugged it and tried again and its just a quick red flash and then nothing. Sooooo, already time to replace something?
EDIT- Can this be deleted? I was browsing around and ended up trying adjusting the trim on the elevation after connecting the battery and it came to life! Problem solved!
