A True List!
A True List!
A friend sent me this, and it looks quite true! Enjoy!
YOU MIGHT BE AN AIRCRAFT MECHANIC IF:
>1. You've ever slept on the concrete under a wing.
>2. You've ever said "Oh yes sir, its supposed to look like that"
>3. You know what JP4/JP8 (Jet A) tastes like.
>4. You've ever used a black grease pencil to fix an overworn tire.
>5. You have a better bench-stock in the pockets of your coveralls then the
> supply system.
>6. You've ever used a piece of safety wire as a toothpick.
>7. You've ever been told to go get "some prop wash and a yard of
> flightline."
>8. You've ever worked a 14 hour shift on a aircraft that isn't flying the
> next day.
>9. (My favorite) You can sleep anywhere, anytime, but as soon as the
> engines shut down you are wide awake.
>10. You've ever stood on wheel chocks to keep your feet dry.
>11. Used dikes to trim fingernails.
>12. Wiped leaks immediately prior to crew show.
>13. Wondered where they keep finding the idiot s that keep making up stupid
> rules.
>14. You've ever had to defuel an aircraft an hour after refueling it.
>15. You've used a wheel chock as a hammer.
>16. You know more about your coworkers than your own family.
>17. You ever wished the pilot would say "great airplane."
>18. You've ever wondered why it takes a college degree to break an airplane
> but only a high school diploma to fix one.
> supply system.
> flightline."
> next day.
> rules.
RE: A True List!
Thanks, Lear, I really appreciated this one. I think I've pretty much exhausted all the aviation jokes via the search engines. So this one is new to me..
RE: A True List!
LMAO
Worked at an airport, I loved the part about the JetA taste and defueling after fueling.
Heres another "Experience":
19.You've set up a duck blind in the hangar to hunt down the birds that have crapped all over the King Air and Citation you just washed.
