You Might Be an RC Modeler If...
You might be an r/c modeler if.....
You are making an inverted low pass and then pull UP on the elevator
You get to the field and realize your transmitter is still on charge at home
You will go flying when it's 104 but you wont cut the grass for your wife cause" it's too hot out there"
You buy a $600 mini lathe to make $5 airplane parts
You can program a multifunction 9 channel computer radio but you can figure out your VCR
You have a dog-eared Tower Hobbies catalog in your bathroom
You spend $12.50 to get your wife some costume jewelry and $365 for r/c stuff and figure everything is even
You consider a Sunday picnic a few hot dogs and some soda at the field
Your wedding anniversary falls on the weekend of a fly in and you actually think about your choices
You shop Toys-R-Us for pilots
You have balls of dust on top of your living room furniture
You have EVER glued your hands together with CA and have had to use an exacto knife in your teeth to cut them apart.
You have built two right wings for a single winged plane
You are shopping for land to build your dream home on and would rather have open pastureland than rolling wooded hills
You have at least 3 planes in separate stages of completion
You think R/C flying should be an Olympic event.
You wear goggles and a silk scarf around your neck on the way to the field
You have at least 10 T-shirts with airplanes on them
You use more waxed paper building planes than your wife does baking
You buy the "wife and kids" a new Pentium 3 computer for Christmas so you can practice with the Dave Brown flight simulator
You introduce your wife as your co- pilot
