Lost in Translation
Lost in Translation
Given that a great deal, if not most, of our gear comes from China or the far east, instruction manuals often can be very interesting reading. Also I was just looking at the front page of RCU and noticed a beautiful Christen Eagle produced by the Dong Hang Model Company......
RE: Lost in Translation
ORIGINAL: Bigshark
GA
This comes from a german EDF gulfstream IV manual"Flying: So now you have run out of excuses it's time to fly. Start the airplane with a strong vim by hand.(a second person as starter would be very good)." -Lousyflyer-
MN
There's a whole website devoted to this sort of thin: www.engrish.com
In my Slow Stick manual it's got a tx diagram with evelattor, dudder, trottle, and aileron clearly marked to help me find my way around my own equipment...
My DF#4 manual says something about "Slowly move the right stick forward. By doing this you can make the helicopter 'walk'"
My favorites, though, are the names on the parts list in my Hydrofoam knockoff manual. Below are some of the written words and the supposed translations:
Elevator Gadget: Control horn
Electricity adjustor: ESC
Non-brush electromotor: Brushless motor
High-octane batteries: 3S lipo
Electromotor pole: Motor mount
Receirer: Receiver
Airfoil stator: little plastic things that reinforce the stabs
Hand sender: Transmitter
Durable board: Plastic sponson reinforcer
Foam part: Main fuse
Hollow strong rod: CF strengthener
There are more; these are the ones I know off the top of my head. I seen to recall that that same manual states that "...if wind's speeds are below 180kmh then you can try to fly..." Well, I HOPE no one's honestly trying to fly in 115mph winds[X(]
Receirer: Receiver
MN
Hilarious stuff!
I'll have to get my Slow stick and E Starter manuals back out. There was also an Chinese made sailplane called an OMEI that had and almost incomprehensible manual I'll have to look for.....
I have just got a new soldering station / soldering iron. The instructions have obviously been translated from Chinese. It is good, but when I use it, I always make sure I follow the instructions:
-This weld machine is an ideal welding tool for an amateur fancier, school, car of electronics, and for maintaining service, producing with labratory.
-Outer shell construction is tightly and firmly packed, and it has good function to instulate the aegis.
-The welding machine is absolutly prohibited to be used to heat the liquid(water,electrolyte and ?) or heat the plastic parts (it will form poisonous air and cause fires).
-After welding, please melt a little solder on the welding mouth before putting the iron back to the frame and turning off the machine. Clean away excrescent solder on the fiery mouth with wet sponge before starting welding next time.
-Please conserve the weld machine's packing box. In cause that we use it for future transportation or put the weld machine into it when we don't need it ,so as to avoid pollution of ash and the eroding of the wet.
1) Put the metal helix of screw frame into the corresponding open crust of the electric soldering irons frame. And use the screw to fasten it and so does the bottom of the frame.
2) Please let the sponge for tidying up glue absorb enough clean water and drop to dry, and then put it on salver.
-The welding of electric components costs not more than two minutes.
-The electric soldering irons and the weld machine can not carry too much man's weight.
-the temperature of the electric soldering irons can reach more than 160*C, if the animal or man touch the heated by the electric soldering irons, we will suffer seriously bum.
-If you press the switch without move, regulating will go on by 10*C every grade til the demanded temperature is displayed.
-...the piezoelectricity sensor will give out sound of alarm.
Well, that's helpful! I'll try not to touch it when it is hot, or sit on it accidently! Any more funny translations?
(By the way, this a soldering iron, NOT a welding iron. However much the instructions say it can, it cannot weld.)
cowana
cowana
ORIGINAL: cowana
cowana
cowana
That was my favorite line.
I am also big fan of the site mentioned in an earlier post. [link=http://www.engrish.com]Engrish[/link]
Location: San Diego but living in Dubai, UNITED ARAB EMIRATE
This isn't quite instruction manual 'lost in translation'....but lost it definently was.
Picture taken in a parking lot of a shopping mall in Dubai. It's supposed to be based on the old bumper sticker "I'm not speeding, I'm flying too low"....but something got messed up a bit here...
Last word reads 'slowly'
ID
ORIGINAL: ChillPhatCat
Out of the manual for my Art-Tech Cap 232: ''Keep model away from flame as it may be subject to transfiguration.''
