If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 3 of 3 FirstFirst 123
Results 51 to 64 of 64
  1. #51
    k_sonn's Avatar
    Join Date
    Feb 2002
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Skymaster L-39 Assembly and Scheme Change
    ORIGINAL: Joe C
    Kirk, bring that nice looking L-39 to Best In The West. Joe C!!!
    Thanks Joe. I'm waiting to see if my vacation request is approved so I can go to BITW. Plan to bring the L-39 and Hunter.
    Kirk
  2. #52
    k_sonn's Avatar
    Join Date
    Feb 2002
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: trioval00
    I finally got a pic of mine and the full scale last weekend.
    Nice looking scheme.
    Kirk
  3. #53
    k_sonn's Avatar
    Join Date
    Feb 2002
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I received the paint mask and dry transfers from Ralle on Friday. Spent today finishing up the painting. I have alittle touch up to do and the painting will be completed. Next, I'll weather it and then apply the dry transfers.
    Kirk
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1793400   Click image for larger version.
  4. #54
    k_sonn's Avatar
    Join Date
    Feb 2002
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    When weathering a multi-colored scheme I like to start with the darker color. I started with one of the dark patches on the left wing. I use dry paint pigment and place it in each rivet, panel line, around the hatch covers, etc., then wipe the surface down with a damp cloth and repeat as needed until I good the desired look.It's not the fastest way to weather but I like the way it looks better than an air brushed wash. More to come.
    Kirk
  5. #55
    k_sonn's Avatar
    Join Date
    Feb 2002
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Top of the left wing is nearly complete. Just need to do the small white section at the root.
    Kirk
ID:	1794191   Click image for larger version.
  6. #56
    Join Date
    May 2008
    Fayetteville, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Looking great Kirk!!
  7. #57
    k_sonn's Avatar
    Join Date
    Feb 2002
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks Gamalier.  Weathering shouild be done before the weekend so I plan to take it to Jets Over Whidbey for static display.  I'll try and better photos then.
    How's your L-39 coming along?  Have you flown it yet?  If so, how did it go?  What's your impression of the DS-77 HST?  Any video?
    Do you plan to make it to E-Jets?
    Kirk
  8. #58
    Join Date
    May 2008
    Fayetteville, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well I maidened mine and everything went fine. Can't be happier with my selection of edf unit! Sadly on the second flight we lost all power after 3 1/2 minutes because we were flying it all the time at 1/2 - 3/4 of power and we landed in the rough. To our amazement the plane came down level all the time. When I inspected a wing got a little T shape crack and some former damage in the front strut and right wing. As I type the paint is drying and all formers were glued, should be flying this weekend. I will turn off the voltage cut off from the ESC (our suspect of the power loss). Besides that planes flew awesome and with plenty of power and given the proven fact that it wont drop a wing no matter how slow it flies that gives me an extra piece of mind. With throttle management and once the batteries are broken in we should get better flying times.
  9. #59
    k_sonn's Avatar
    Join Date
    Feb 2002
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The left side of the fuse has been weathered and most of the dry transfers that go on the left side have been added to that side.
    Kirk
ID:	1794648   Click image for larger version.
  10. #60
    k_sonn's Avatar
    Join Date
    Feb 2002
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: gamalierlozada
    Hey Gamalier,
    Sorry to hear that. The manual for the HST fans recommends turning off the voltage cut off setting. Although these fans are very effecient, they can pull a lot of amps on a fast throttle up due to the rotor loading up. I have throttle delay programmed into the ESC on my Hunter and will do the same on the L-39. The delay allows for a slower spool up, much like a turbine, and helps prevent voltage spike and ripple.
    Bring your L-39 out to E-Jets. I won't have my L-39 ready in time for E-Jets but I'll have the Hunter out there.
    Kirk
  11. #61
    RalleKnalle's Avatar
    Join Date
    Apr 2004
    Falkenberg, GERMANY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Kirk,
    had you probems with the dry transfers on that matt/flat surface? did you sand the suface before applying the transfers? sometimes it is tricky to apply the rub ons on very matt surfaces...sanding with scotch brite grey or 2000 grit soft sanding pads do help.
    looks good, Iยดd like that black and white stencils...
    Ralle Tailor MD
  12. #62
    k_sonn's Avatar
    Join Date
    Feb 2002
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: RalleKnalle
    Hi Kirk,
    looks good, I´d like that black and white stencils...
    Hi Ralle,
    I used Testor's Model Master flat enamel paint and the dry transfers are sticking to it with no problems. For years I've used the other well know masks and dry transfers, but after using your producton two projects, you have a customer for life.
    Kirk
  13. #63
    k_sonn's Avatar
    Join Date
    Feb 2002
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I haven't worked on the L-39 in a while so it was time to dust it off and get crankin on it.
    Photos 1 & 2: Made some air tank mounts out of light ply and hysoled them in place.
    Photos 3 & 4: The forward equipment tray was made up. I made it so the nose retract and brake air tank air lines could be disconnected in order to remove the tray.
    Photo 5: The forward equipment tray and air tanks installed .
    Photo 6: The battery tray was made up of from a carbon fiber honeycomb sandwich material. Photo shows the battery tray installed.
    Kirk
ID:	1861184   Click image for larger version.
ID:	1861185   Click image for larger version.
ID:	1861186   Click image for larger version.
ID:	1861187   Click image for larger version.
  14. #64
    k_sonn's Avatar
    Join Date
    Feb 2002
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I was going to update this thread but since I can't post photos, I guess that isn't going to happen. The update can be viewed on the RCJetAddiction site.
    Kirk
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
