Reload this Page >
C-ARF Ultra Flash build Thread + Video
Old 04-06-2017, 07:14 AM
  #5726
Dblex
My Feedback: (81)
Dblex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dblex is online now
Old 04-06-2017, 02:44 PM
  #5727
paulhat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Dblex View Post
I have three on the fuse tank (2 vents and 1 clunk) So your "Y" connecting both vents on the fuse tank to wing tank clunk?
Just plug the spare breather. Y fitting will just add weight with no benefit.
Paul.
paulhat is offline
Old 04-06-2017, 03:00 PM
  #5728
Dblex
My Feedback: (81)
Dblex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Paul.
Thanks Paul!
Dblex is online now
Old 04-06-2017, 09:06 PM
  #5729
737Driver
737Driver's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, what Paul said!
737Driver is offline
Old 04-07-2017, 07:10 PM
  #5730
why_fly_high
My Feedback: (19)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got the first flight on my UF. REALLY PLEASED! Left the gear down but could still see that this thing will be fast once I open her up.
I am running the wing tank and fuse tank for fuel. I have heard that the fuse tank has some unuseable fuel. About how low is safe? 1" from the bottom? 1/2"? I flew it pretty mildly and didn't use much of the fuse tank after 5 minutes.
Thanks!
Dan
why_fly_high is offline
Old 04-07-2017, 08:19 PM
  #5731
BoomerSooner
My Feedback: (80)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I let mine run down to about a 1/4 - 1/2" above the square front part of the tank. I flew for 6:30 - 7:00 a flight typically.
parker
BoomerSooner is offline
Old 04-07-2017, 08:25 PM
  #5732
txshan130
My Feedback: (113)
txshan130's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks!
Dan
Yep, the UF is one awesome jet. Approaching 400 flights between the two I have and still am not bored! Congrats on the first flight...Also, I normally land with about 1" or greater in the main tank
txshan130 is offline
Old 04-07-2017, 08:50 PM
  #5733
wblombard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Paul.
I was very close on maidening the UF yesterday, however my main jet tech tank fitting created a leak so back to the operating table she went.
When i tested the main tank i replaced the fitting with my wing tank fitting to establish if it was the fitting or the tank. Im glad to report it was the fitting. So i connected up the entire system and started fueling her up. On de fueling I noticed once saddle tank was empty and the other not...obviously the fuel is following the path of least resistance BUT what was starnge is that my pipe lenghts were identical.
So im not keen on having a model that creates doubt regarding fuel and flame outs..so i changed my setup to be 1 main tank and 1 wing tank. I also plugged the spare breather. Must say i feel a lot more comfortable.
wblombard is offline
Old 04-07-2017, 09:10 PM
  #5734
why_fly_high
My Feedback: (19)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A few pics my buddy took today.
ID:	2208811   Click image for larger version
ID:	2208812   Click image for larger version
Old 04-08-2017, 11:12 AM
  #5735
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice pics.
Dave Wilshere is offline
Old 04-09-2017, 11:34 PM
  #5736
wblombard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Couple of build pics from my Ultra Flash.
Running Wing tank to main tank, I will install the saddle tanks after the maiden for smoke.
I have been searching the tread regarding flap setups and every one has different settings. So going to start off with the following:
Take off flap 27mm (-1mm down elevator mix)
Landing flap 75mm )-5mm down elevator mix)
Crow on full flap +6mm
CG 232mm from LE cut line (tanks empty, CAT full, Gear down)
Aileron +9mm /-10mm (up/down) 40% expo
Rudder 45mm each way 40 % expo
Elevator +10mm/-11mm (40% expo)
Got these settings on here from a previous post from Phil (Thanks) Hopefully they are good.
Any comments please shoot!
Name:	Avionics Plate Pic 3.jpg
ID:	2209128   Click image for larger version
Name:	Avionics Plate Pic 2.jpg
ID:	2209129   Click image for larger version
Name:	Avionics Plate Pic 1.jpg
ID:	2209130   Click image for larger version
Name:	Final Avionics Pic 4.jpg
ID:	2209131   Click image for larger version
Name:	Final Avionics Pic 5.jpg
ID:	2209132   Click image for larger version
Name:	Final Avionics Pic 6.jpg
ID:	2209133   Click image for larger version
Name:	Final Avionics Pic 7.jpg
ID:	2209134   Click image for larger version
Name:	Final Avionics Pic 8.jpg
Name:	Avionics Plate Pic 9.jpg
ID:	2209136   Click image for larger version
Name:	Avionics Plate Pic 10.jpg
ID:	2209137   Click image for larger version
Name:	Avionics Plate Pic 11.jpg
Old 04-10-2017, 12:38 AM
  #5737
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Like always it depends how you like the model to feel, Phil needed a soft set up, for me its not enough Flap, turbines vary with idle thrust and with a clean model like the UF a small increase in flap angle makes a big difference to slowing it down. I'd say 85mm minimum, I still use the full 100mm.
Also the joining nipple you have used on the overflow-what size hole did that have? If you restrict the line pump figures will be high and an air leak is more likely as you have gone from one joint to three!
Dave
Old 04-10-2017, 02:11 AM
  #5738
wblombard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave
Hi Dave,
Thanks for the input, noted regarding flap and will proceed with 90mm for the initial flight. I do recall the UF at the field struggled to slow down with 75mm flap, however no crow was utilized. Since then he unfortunately crashed it due to a flame out.
Regarding my fuel line setup, with this being my first jet build there were a couple of learning curves. Firstly the fuel tanks I ordered came with a 8mm diameter fitting while I planned a 6mm setup.
I contacted Gary at jet tech whereby i purchased a few reducers from 8mm down to 6mm.
So, my wing tank over flow is 8mm dia tubing, the wing tank feed to main tank is reduced from 8mm to 6mm whereby i connected the jet flow fitting (http://www.dreamworksrc.com/catalog/...Kero-Fuel-Only) This feed to the main tank needs to be changed from 6mm to 8mm dia in order to fit on my main tank over flow (colorless tubing). The other main tank over flow is just stopped using a festo stopper.
The main tank feeds the CAT via a 8mm dia tubing (yellow tygon), CAT feeds pump via 6mm tubing.
I hope that makes sense what im trying to explain above. Yes there are a number of step downs but the main feed to the CAT is a straight 8mm dia, I dont forsee a problem unless you advise otherwise.
Looking forward to your thoughts
Old 04-10-2017, 03:46 AM
  #5739
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK, size should be OK if the joints are mechanically sound. I would lock wire the clear and other side of tygon to be sure in this case
Dave
Old 04-10-2017, 04:21 AM
  #5740
wblombard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave
Noted! Thanks, appreciate the advise...I need it
Old 04-10-2017, 08:11 AM
  #5741
MaJ. Woody
My Feedback: (26)
MaJ. Woody's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave I have a question. I limited my max flap deflection to 75MM solely because any more flap than that and the curved plastic upper fairing on the flap falls below the wing TE. I was afraid if this was exposed it would grab the wind and rip it off. Does what I am describing make sense and do you see this as an issue? I can easily dial up the travel to as much as I would like if what I described is not a problem. Hoping to complete my build some time this century. Still plugging away at my Cockpit LOL.
MaJ. Woody is online now
Old 04-10-2017, 09:38 AM
  #5742
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You mean like this? That is 100mm flap. No problem at all.
ID:	2209166   Click image for larger version
ID:	2209167   Click image for larger version
Old 04-10-2017, 11:57 AM
  #5743
MaJ. Woody
My Feedback: (26)
MaJ. Woody's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the pictures Dave. I will have to check mine again. I think I may have a larger gap between the curved plastic fairing and the wing TE.
Old 04-10-2017, 12:03 PM
  #5744
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Its a fibre glass moulding. makes no difference, the air is all turbulent there, so no issues.
Old 04-11-2017, 02:16 AM
  #5745
MaJ. Woody
My Feedback: (26)
MaJ. Woody's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Awesome.
Thanks Dave!
Old 04-11-2017, 07:23 AM
  #5746
why_fly_high
My Feedback: (19)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A few more pictures from the latest flight. This was just diesel for smoke fluid. Will have to try real smoke fluid soon.
ID:	2209301   Click image for larger version
ID:	2209302   Click image for larger version
ID:	2209303   Click image for larger version
Old 04-13-2017, 07:41 PM
  #5747
jesse2357
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
quick question, I'm putting a jet munts 140 in mine, the destructions say 15 - 18mm from chrome piece on a jet cat. The Jet munts has a really short cone on the turbine is that measurement still relevant? Normally wouldn't you just measure from the end of the tailcone? also is there a better method of lining up the turbine in the thrust tube then eying it down the tube?
jesse2357 is online now
Old 04-13-2017, 09:52 PM
  #5748
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No it's not. Turbines like the JM did not exist when we did the manual. 30mm from the tail cone to pipe is about right, you can make discs, but eye ball is perfectly good for the job in this case.
Dave
Old 04-15-2017, 04:57 AM
  #5749
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
'Little Stevie' giving his UF P-120 JR 28x combo a work out at our local field this am.
ID:	2209870   Click image for larger version
ID:	2209871   Click image for larger version
ID:	2209872   Click image for larger version
ID:	2209873   Click image for larger version
ID:	2209874   Click image for larger version
ID:	2209875   Click image for larger version
ID:	2209876   Click image for larger version
ID:	2209878   Click image for larger version
ID:	2209879   Click image for larger version
ID:	2209880   Click image for larger version
ID:	2209881   Click image for larger version
ID:	2209882   Click image for larger version
ID:	2209883   Click image for larger version
ID:	2209884   Click image for larger version
ID:	2209886   Click image for larger version
Old 04-18-2017, 04:17 PM
  #5750
Dblex
My Feedback: (81)
Dblex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, RCU isnt cooperating on the website, so I will do the best I can to read your responses. Forum looks crazy for me right now.
Ok, anyone have any Kingtech 140G2 install pics to share? I am ready to put mine in and Im curious how you lined her up and made sure she was right down the middle of the pipe. The old 140's seem to lay in there just fine. The G2 seems to be a bit smaller and needs adapter plates.
Pics would be helpful!
Thanks!
Dblex is online now
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
