C-ARF Ultra Flash build Thread + Video
Reply
Old 08-13-2017, 06:42 PM
  #5876
Dblex
Dblex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Smile
Quote:
Originally Posted by setxws6 View Post
Nah Nah you want to sell it....hahahaha
Lmao! I was just trying to help you out!!! Then again I was really happy with keeping this sport scheme. I can see this thing a mile away!!! Not to mention that I wasn't expecting to get much flying time since school and sports were right around the corner for my kids. Then all of a sudden, my son is asking me to fly bigger stuff. WAIT WHAT!!??? So I have been getting him going on a few projects. He got more flying time this weekend than I did!! It's not an ultra flash video but he is pure entertainment! For some reason the resolution goes to SD but it is available in 720
This weekend I did spend time with full flaps and slow flight. It is mind blowing how this thing handles it. Then again, I can relate to the guys who are overpowering this beast. She just seems to handle anything you throw at her. I am truly impressed. You guys on this thread have really contributed to a great experience with my UF.
Thanks for all the help.
Dblex is offline
Old 08-14-2017, 03:45 AM
  #5877
setxws6
setxws6's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well that's great I'm glad I didn't buy it from you and you're getting to enjoy it, it's an amazing jet. I've been working a little on mine new Cayman scheme Flash over the weekend and so far it's been going smooth.
setxws6 is offline
Old 08-17-2017, 12:42 AM
  #5878
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just had in one of the green Neon Cayman UF kits. Colour does not photo well, but it will be bright!
Name:	DSC_0721 (Small).JPG
ID:	2228240   Click image for larger version
ID:	2228241   Click image for larger version
Name:	DSC_0714 (Small).JPG
ID:	2228242   Click image for larger version
Dave Wilshere is offline
Old 08-21-2017, 01:55 PM
  #5879
VK96
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Horizontal stab alignment
Well I decided that if one UF is good, 2 must be great! When building this one I've run into an issue with the horizontal stab not aligning perfectly due to where the dowel meets the hole. I've cleaned all the seams, but as you can see there's about a 1mm difference from it sitting flush. Obviously this will affect the incidence, and I'm just curious how big of a deal it is? If it is, how to correct it?
ID:	2228875   Click image for larger version
ID:	2228876   Click image for larger version
VK96 is online now
Old 08-21-2017, 02:21 PM
  #5880
Dblex
Dblex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is mine.
ID:	2228879   Click image for larger version
Dblex is offline
Old 08-21-2017, 02:46 PM
  #5881
VK96
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Dblex...looks about the same as mine. No issues I presume?
VK96 is online now
Old 08-21-2017, 02:54 PM
  #5882
Dblex
Dblex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
10 gallons through this beast so far. The only issues I have is getting my nerves calmed down after multiple high speed runs...."just sayin"
Dblex is offline
Old 08-21-2017, 05:03 PM
  #5883
setxws6
setxws6's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's mine for reference. Is there a gap between where the fuselage and top leading edge meet? If there is i think theres room for making it tighter
setxws6 is offline
Old 08-21-2017, 06:52 PM
  #5884
Dblex
Dblex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Always a Cayman Neon Yellow show off in the bunch....
Dblex is offline
Old 08-21-2017, 07:14 PM
  #5885
VK96
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, there's a hairline gap on the top surface of the leading edge...as well as the bottom center portion sitting about 1mm proud of the fuse. My other Flash looks like yours with it completely flush. Any ideas on how to snug it up?
VK96 is online now
Old 08-22-2017, 04:26 AM
  #5886
setxws6
setxws6's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Well what can I say, it's eye catching!
Quote:
I'm thinking that the dowel pin is the culprit. You'll have to see if you can trim it a bit, but watch out because you don't want it to have any play. Or you can leave it as is and you probably won't notice a difference in flight. Probably only need a few extra clicks of down trim if anything.
setxws6 is offline
Old 08-30-2017, 09:27 AM
  #5887
Thai Tiger
Thai Tiger's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So my first Ultra flash build.
What a pain the wing servo covers are, particularly for rigging, right?
I came up with a work around that I just thought to share to hopefully make somebody else's life easier.
First make up the wing box mounts and install the servos and selected arms.
Next, center the AILERON servo arm both at 90 degrees to the case and in the center of the aileron arm cutout on the Carbon panel, adjusting as required, then drill 2 small holes thru the Carbon panel and into the wing box servo mounts, use the screws to locate the wing box mount on the panel, adjust as required.
Remove panel and make up a 1/4 inch temporary custom plywood piece using the Carbon panel mounting holes and the two small holes previously described as a guide.
Install the wing box mounts onto the plywood jigs and you can now adjust the servo arms, control throws and rod lengths without continuously installing and removing the panels.
Once rigged, remove the plywood pieces, add a dash of Aeropoxy or your chosen epoxy to the wing box servo mount & the Carbon wing panels then mate up, once again using the the two additional small holes as a guides.
Of course there will be some minor adjustments to the movements once the Carbon panels are permanently installed.
Attached pictures speak a 1000 words.
Hope I've helped.
Thai Tiger is offline
Old 08-31-2017, 06:12 AM
  #5888
robersteam
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Where´s the attached pic?
robersteam is offline
Old 08-31-2017, 10:47 AM
  #5889
VK96
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got a few flights on my new UF with the tail issue. Flys just fine, but does carry less "up" trim than my other one with almost identical CG's. Cheetah 160 SE...she's a beast!
VK96 is online now
Old 09-01-2017, 07:10 PM
  #5890
Thai Tiger
Thai Tiger's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry, i can't seem to put the photos on the post, please see my photo gallery.
Old 09-02-2017, 08:54 AM
  #5891
setxws6
setxws6's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good deal, didn't think it should make much difference
setxws6 is offline
Old 09-04-2017, 08:12 AM
  #5892
Thai Tiger
Thai Tiger's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
To all the guys running the Jet Central Cheetah.
How do you manage the electrical plug on the engine, are you guys cutting a clearance hole in the carbon by-pass?
Photo would be nice, please.
Old 09-04-2017, 03:51 PM
  #5893
VK96
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I rotated the engine 45 degrees in the aluminum mount, placing the connection right between the 2 halves of the by-pass. Easy to slide the cover in and out. Will get a pic when I'm back home for ya.
VK96 is online now
Old 09-04-2017, 04:11 PM
  #5894
MaJ. Woody
MaJ. Woody's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I rotated my engine as well. See my build thread for detailed photos.
MaJ. Woody is offline
Old 09-05-2017, 06:41 AM
  #5895
VK96
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here ya go...FWIW I found the 30" cable to be a bit short. I spoke with Jose and they make a 36" that I'm going to grab.
VK96 is online now
Old 09-14-2017, 06:45 AM
  #5896
Thai Tiger
Thai Tiger's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you very much.
Old 09-14-2017, 04:29 PM
  #5897
Thai Tiger
Thai Tiger's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Wonderful build thread, thank you very much.
Old 09-24-2017, 04:53 PM
  #5898
setxws6
setxws6's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finally finished my neon yellow Cayman scheme Ultra Flash. Maiden her today and put 3 successful flights on her. A few little things to tweak before next flight but as always, such a wonderful jet. Mine has a Jet Central Rhino (36lb thrust older version) so there's plenty of power and thrust. Jet came out to exactly 25lbs without fuel, so I estimate around 31 lbs with a full tank.
ID:	2233559   Click image for larger version
ID:	2233560   Click image for larger version
setxws6 is offline
Old 09-24-2017, 06:00 PM
  #5899
Dblex
Dblex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Awww man that is sexy!
Dblex is offline
Old 09-24-2017, 09:03 PM
  #5900
737Driver
737Driver's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
setxws6
That color scheme is AWESOME!!!! The photos are really nice as well. I'm really digging the new color schemes. Congrats on your maiden.
737Driver is offline
Reply
Display Modes
