If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 36 of 223 FirstFirst ... 2634353637384686136 ... LastLast
Results 876 to 900 of 5574
  1. #876
    Join Date
    Jun 2002
    Watford, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: C-ARF Ultra Flash build Thread + Video
    I get asked a lot about fitting canopy glass, everyone has their own method. Mine is to clean up the frame to be constant thickness, inc the part where the tape is on the joint. Then I trim the canopy glass as shown earlier. Then you must make the first attachment with the canopy frame on the fuselage to keep a good fit. I use ZAP Slow (yellow) and a foam safe kicker which stops misting. I then tack the centre only front and back. This sets the frame gap. With this dry I take the frame off and roll/push the glass around its curve in the centre, where the hoop is and another single tack of CA is placed and kicked either side. These photos (difficult to take) show the glass with just four drops of CA holding it in place. If you are out of alignment you can break the joint and adjust. With this stage complete I add a few more tacks and then squeeze ZAP56 canopy glue around the edge and that's it!
    Dw
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1636498   Click image for larger version.
ID:	1636499   Click image for larger version.
ID:	1636500   Click image for larger version.
ID:	1636501   Click image for larger version.
    Motors & Rotors. JetCat, Powerbox, Intairco, Behotec, CARF-models Rep. JR Propo for ever!, Jet 1A, MAP, Airtech Germany, Jet Tronics.
  2. #877
    Join Date
    Jan 2005
    Brisbane, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    DW, sounds good.
    Nothing better than having a sport jet to do what you want with it!
    Goodluck getting it ready to fly, hope it goes well. Will read future developments.
    Stephen
  3. #878
    Join Date
    Dec 2002
    PERTH, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey guys,
    I am thinking of fitting a smoke system to my ultra flash and was going to put a couple of 20oz Dubro tanks on either side of the fuse where the inlet joiner would have been as I have seen some others do. I am just a little worried about restricted air flow to the turbine with that setup. I was going to fit a jetcat smoke pump to the jet.
    Any comments or tips??
    Thanks in advance.
    Kind regards,
    Craig.
  4. #879
    phjoker's Avatar
    Join Date
    Sep 2005
    Vernon, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Craig B.
    Hey guys,
    Thanks in advance.
    Kind regards,
    Craig.
    On my Original I have 2 Dubro 24oz tanks, a Rhino for the turbine, and apoox 75 flights and have never had a problem with mine what so ever
    Pete H
    Jet Central Falcon
    Jet Central Rhino
  5. #880
    Join Date
    Dec 2004
    Broken Arrow, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I had installed a 40oz dubro tank in the front bay, fits nicely behind the steering servo with an equipment tray on top for the rx, ecu and valve. I mounted two small air tanks beside the turbine / inlet joiner and am able to retain the joiner and bypass. I was able to use the wing tank for smoke and also mounted the pump in the wing making hook up simple.
    Sorry I don't have any pics.
    Dale
  6. #881
    Join Date
    Dec 2006
    , AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi All,
    Finally ordered my Ultra Flash. Very excited
    Decided to go with the Thunderbirds scheme. Should look a bit like Colins one that he showed in an earlier post -
    Going to put a Kingtech K-140 in the old girl. From all reports they seem to be a good engine. Have allready ordered it so I guess I will find out.
    Paul Hatfield.
  7. #882
    Colin Allen's Avatar
    Join Date
    Feb 2010
    RobinaQLD, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Congratulations Paul!! Mine is a somewhat modified Thunderbirds scheme, with some of the standard marking removed, and I've ordered a set of custom decals to go on it, so it looks a little bare in the above photo. The stock Thunderbirds scheme looks great as is I think though.
    I started on my build tonight actually - got the stabs largely finished. I'll post some more photos once I've got the decals on it.
    I've no direct experience with the Kingtech, but from what I've heard they are pretty good. Not quite up there with Jetcat in terms of build quality, but more power apparently. I'm putting a JetCentral Cheetah in mine.
    Cheers,
    Colin
    https://www.facebook.com/ColinAllenRCPilot
    CARF Ultra Flash, CARF Ultra Lightning, CARF Tucano, Skymaster Large Hawk, 2.5 Futura, CARF Spark (Turbine), Skymaster Viper 2.6, CARF 2.3 Extra, CARF P-47
    Building: Skymaster F-14, CARF L-39
  8. #883
    Ali's Avatar
    Join Date
    Apr 2002
    Northamptonshire , UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My Ultra Flash as been thrown in at the deep end it seems. Three international events back to back have seen it do a boot full of flying. It's unusual for me to log this many flights on a new sports jet back to back as I have done with the flash, but the truth is that i really do love this model.
    I have to admit to not being the biggest fan of the old straight wing flash. I find the Ultra to be in a league apart. So much smoother and precise, with less coupling yet still able to slow down to a decent slow speed and operate out of a small grass strip. I have played about quite a bit with the set up untilI found one that suits me. I found it was easy to get in a situation where you had too much flap, and the model became a little pitch sensitive as it slowed down. I also thought that with a little too much flap it could dump too much lift and drop that last bit onto its gear instead of flying onto them. I reduced my flap and ran a little crow to aid the slowing down. I now find that i can do one of my tight descending circuits to land ( Usually within tight proximity to the landing point) and slow down even despite the step decent. Yet still not gain too much speed when I level out to flare for touch down, and best of all the model keeps flying right up till it touches down.
    I found that I had to run really quite a large amount of down elevator with full flap and crow in order to stop it ballooning. Much more than I expected.
    I also found the model rolled so much better ( Especially fast twinkle rolls) with Ail differential. ( 25% more up than down on each aileron worked for me)
    The model is so strong and resilient. I think i managed to log over 15 flights with it this past weekend, and these included some pretty hard flying. A spanner nor wrench went near the model all weekend! The more I fly it the more I love it. I will try to get some measurements on my surfaces when the van is unloaded ( Not sure when I will have the energy for that as I am beat right now) Till then, I took some photos while I was in Finland last week of the flap/ ail and elv set up that I run for landing.
ID:	1639827   Click image for larger version.
ID:	1639828   Click image for larger version.
    Al's Hobbies, Horizon Hobby, Airworld, BVM, Jet Cat, Skymaster, Rc Jet Centre,pull over, Tomahawk, C-ARF, Jet-Teng,Kingtech
  9. #884
    Join Date
    Jan 2007
    tampa, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ali I am glad you like this model....I love mine...I would love to see a video of you flying it...waiting for florida jets to get here again to see you fly...take care.....
  10. #885
    AFTERBURNER1's Avatar
    Join Date
    Jun 2003
    Anaheim Hills, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I now have 15 flights on my newly upgraded ultra flash. Ali is correct in saying that is one sweet flyer.
    Oh yeah,, mine has CROW on it as well and it works FANTASTIC!!!! Don't be afraid of the crow !!!! Must be a grass euro thing or something
    KINGTECH TURBINES
  11. #886
    Join Date
    Jun 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Not afraid of it...just don't need it on mine! higher weight is probably a factor, all I see with less flap is more lift and the raised ailerons needed to re add drag.
    There is no such thing as a correct set up, its what works for you.
    Dw
  12. #887
    Join Date
    Jan 2007
    tampa, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    we fly off 600 feet paved ... over 75 flights on the ultra.. land at the numbers..no old crow needed...just after i fly....
  13. #888
    Join Date
    Feb 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Started the build on my UF yesterday. I'm still finishing off my CARF Extra 2.1, but I couldn't wait
    If anyone has any ideas about putting Futaba servos in the stab, forget it. When they say 19mm max servo thickness, they mean it! I ended up using 8411's and even they required reshaping of the metal servo mounts and judicious sanding of the inside of the stab to get the servo panel to sit flush. I'll be using BLS155's everywhere else. Overkill I know, and call me paranoid (and maybe just lucky), but by overkilling on the servos I've never had a single in flight servo failure.
    Anyway, here's my stab... the only thing different from standard is I'm using machined clevises I got from Intairco. 3mm pin through the horn secured by an e-clip. Zero slop, stronger and more secure.
    Cheers,
    Colin
    ... thanks Ali for the detailed flight report
  14. #889
    wojtek's Avatar
    Join Date
    Dec 2001
    nj, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Finally moving along on my UF .. few quick questions ....
    1: anyone here using the Tam pipe ? I see that the tam pipe fits OVER the carbon bellmouth whereas the CARF pipe fits INSIDE the carbon bellmouth. Has anyone had head / flame damage on the carbon belmoth with it being inside the pipe ?
    2: Smoke ... shere are you guys fitting your smoke tanks? im thinking of 2 16oz on the sides of the intake ducting feeding a 24 oz hopper under the cockpit ..
    3: using the Pro Link gear, has anyone needed to trim any strut lengths to get the correct on-the-ground incidence ?
    thanks Guys
    ~V~
  15. #890
    wojtek's Avatar
    Join Date
    Dec 2001
    nj, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I cant wait to get this jet up in the air ... another two weeks should do ...
    For all you rally racing fans, you know what scheme this is [8D][8D]
    ~V~
  16. #891
    dubd's Avatar
    Join Date
    Aug 2007
    Bay Area, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Wojtek, I have tam's pipe and I have zero issues after 50+ flights. For smoke, I am using 2 24oz dubro tanks set up just like phjoker. I am using Pro Link struts/gear and had to add washers in the retracts (mains) to extend them by a few mm. Otherwise the tires would not go into the wells.
  17. #892
    wojtek's Avatar
    Join Date
    Dec 2001
    nj, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    super, that's all the info I needed , and looks like its on to completing this one
    thanks !
    ~V~
  18. #893
    Join Date
    Jan 2007
    tampa, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    looks really cool.. you will love this jet... most fun sport jet i have flown.. i hope my new ultra lightning makes me as happy as this jet does..
  19. #894
    dubd's Avatar
    Join Date
    Aug 2007
    Bay Area, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here are some pics of my UF with Dave Shulman's decals.
ID:	1640968   Click image for larger version.
ID:	1640969   Click image for larger version.
ID:	1640970   Click image for larger version.
  20. #895
    Join Date
    Jan 2007
    tampa, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Looks great..I have the same scheme...shows up so nice in the air....
  21. #896
    mtnflyer14's Avatar
    Join Date
    Jan 2006
    Colorado Springs, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Where did you get the Shulman graphics? When I look on the website under decals and graphics, there are 'no entries'.
    Regards,
    Gus
    AW Extra 260/ZDZ Super 80; Elan/K-100; GJC Viperjet/K-80;
  22. #897
    dubd's Avatar
    Join Date
    Aug 2007
    Bay Area, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I sent Dave an email. His contact info is on the site.
  23. #898
    Join Date
    Jun 2003
    Anaheim Hills, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I ordered the touch up red paint and hardner for a little touch up on my red checker flash.
    Questions
    Is the red the same red for this scheme and is the paint single stage with clear in it?
    KINGTECH TURBINES
  24. #899
    Join Date
    Jun 2003
    Anaheim Hills, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: dubd
    Kissing that Shui booooooootaaaaaayyy
    KINGTECH TURBINES
  25. #900
    dubd's Avatar
    Join Date
    Aug 2007
    Bay Area, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: AFTERBURNER1
    ORIGINAL: dubd
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
