C-ARF Ultra Flash build Thread + Video
#2126
RE: C-ARF Ultra Flash build Thread + Video
Behotec c36-2 retacts and trailing legs
can anyone show me the correct sequence on assembling te trailing legs with the brakes and axle
currently i have an axle that came with the brakes, a washer and nut , the brake "disc" and the wheel hub
however , sees like i lock the hub and brake when tightening the axle
if anyone can pdf the instructions that should have come with the retarcs - even better - i found a set on altecare , but they are with the old type legs
i have the airtech trailing legs from germany and brakes
thanks
thanks
#2127
ORIGINAL: Dave Wilshere
Jack
I have just finished assembling a dinning table where i thought a building bench would fit
Dave
Jack
Dave
#2128
ORIGINAL: izzy
currently i have an axle that came with the brakes, a washer and nut , the brake ''disc'' and the wheel hub
thanks
thanks
Put some thread lock on the thread, screw in the axle bolt leaving a tiny amount of wheel free play, put the nut on and lock that against the leg.
Dave
#2129
ORIGINAL: Craig B.
Watta ya talking about Dave.......a dining table IS a building bench!
Jack
Dave
Jack
Dave
Err true, but even with the extension in its not really long enough for some of my projects I have a free flight plan I have wanted to build for sometime, so I can at least pin the wings to the table!
I have a Ripmax Hunter to finish before next Friday, so I can see a use for the table very soon
Dave
#2131
ORIGINAL: izzy
Dave thanks
what about the washer
where does that go
thanks
Dave thanks
where does that go
thanks
regards
Dave
#2132
My Feedback: (22)
ME
I believe there are a couple sets of axles that come with the latest AT struts. One set will fit and the others do not. Good luck
ORIGINAL: izzy
thanks
thanks
#2133
wheel wells
there are painted wells that are supplied with the kit , that they refer to cutting and fitting
the are u shaped , however they are deeper than the actual well in the wing
is anyone using them - these are not the covers that attached to the trailing legs , but the ones under neeath them, supposedly to make a neater install, however if i need to cut the lips as they are hi , then there is no place to glue them
tried to attach pics
#2134
ORIGINAL: izzy
wheel wells
wheel wells
They are from the CF model with a thicker wing!
Dave
#2135
If your worried about how itl look without them Izzy, you could always add a strip of either black vinyl or carbon effect decal to the same area, looks a little better than seeing the bare surface of the top wing skin, I've done this on my Classic and it just finishes it off nicely without the need for any cutting or glueing
Jame
Jame
#2136
Ok guys whats the trick in getting the top of the bypass to fit around the motor, and stay in place. Every time I get it into place one of the corners jumps up.
Once the bypass "fits" how do you get the two into one air input inplace ARRRGGGE [>:][:@]
The Motor came back for Motors and Rotors after being sent back to JetCAt for a service and Compresor change, Great Service from both companys.
Should have the Ultra Flash finished by the weekend, and get it flying at Long Marston on Sunday
Peter
Peter
#2137
front retract
what slot are you all using on the steering arm standoff that controls the front l gear leg
when tightening i mistakedly broke the standoff and i am left withjust the last slot
picture of steering arms is from the manual , however , mine have 1 slot on them left only !!
#2138
Izzy
I normally use the outer most slot, but you will probably be OK with inner if you reduce the servo arm radius too. If you have clear silicon put some around the closed loop wire and steering arm with the gear down, let it set before retracting the gear. It stops the wires snagging
Dave
Dave
#2139
With the lower half of the bypass in place fit the 2 into 1 joiner followed by the upper half of bypass, wrap around Velcro holds it in place.
Rob.
Rob.
ORIGINAL: miniman
Once the bypass ''fits'' how do you get the two into one air input inplace ARRRGGGE [>:][:@]
Peter
Peter
#2140
Thanks Rob, but its the bit that those instructions miss that is the problem.
I have fitted the half under the motor, and fitted the 2 into 1 joiner....
Then I cant get the other half of the cover to go into place. The fuel lines, power cable and motor mounts stop the cover sitting/mounting over the under cover.
I can get one side to fit, then the other springs out. It looks such an easy job in the pictures and your text, but it has taken me at least 3 hours!!
Perhaps I am trying to be too perfect.
Peter
#2141
My Feedback: (73)
Man, this was a tight fit !, but i have the smoke tanks in WITH the full bypass .. The intake duct had to be ground down at the side lip, and them i rejoined it with some carbon cloth. After all was in place, there is barely room left to squeeze the wires and plumbing by !
oh yea, also to anyone using these saddle tanks, MAKE SURE TO CUT DOWN the wing mounting bolts ... if too long, they will puncture into the tanks
~V~
~V~
#2143
My Feedback: (73)
The JC Rhino has a FOD screen on it and the frame blocks off a lot of the gap at the inlet between the bypass. These cheater holes allow the bypassed area to suck more air in if needed. This also helps draw ambient air in from the fuselage keeping things cool.
I have found that on the ground I get more thrust out of a bypass set up with cheater holes. In the air, things change at speed im sure with more airflow through the intakes, but that's not possible for me to check , lol ..
Honestly, with the 37lbs pushing out of this thing, im sure not using a bypass at all would have not made a difference anyway ... I think a bypassed install is just cleaner and neater
~V~
~V~
#2144
Ok, no sure why that is, maybe you have a rogue bypass molding? Just to be sure I timed a remove/install which took less than 10 seconds for both. Possibly my my install is not as neat?
Rob.
Rob.
ORIGINAL: miniman
Peter
Peter
#2145
Hi Guys
Rob the only difference to your tidy fiting is the size of the turbine, the P120 fills much more of the space, but after a bit more trimming and refitting the top of the jet tube to give a little more space at the top, I now have the cover in place. I got a bit carried away with the dremel where I thought was stopping the cover fitting, hopefully that should not detract from the benifits of the enclosed bypass.
That said I am glad I dont have the saddle tanks in there as well.
Peter
Peter
#2146
Hi Guys,
Where do you install the smoke tube?
Just behind the turbine in the thrusttube, or in the back @ the end of the thrusttube?
Any information or pictures would be great :-)
Regards, Henk
Regards, Henk
#2147
ORIGINAL: Henk Visser
Hi Guys,
Regards, Henk
Hi Guys,
Regards, Henk
Rob.
#2148
ORIGINAL: miniman
Hi Guys
Peter
Hi Guys
Peter
Fitting the saddle tanks was a bit of a challenge as others have found, only reason I have them is because I'm finding it difficult to kick the smoking habit
Rob.
#2149
Wow = great posts , and very informative
thanks guys
What i am really findinghard is trying to work from the instructions manual - a lots seems very vague
for example , fittine the main tank - it tells you to place a strip of 3mm balsa at the back of the tank, and then another to stop it from moing back
then to place a strip in the front and to add 3mm packers - and mentions this being very important step - but i read through and through and cant find out why
also how do you stop the tank from moving - velcro / dbl sided tape? silicone glue ?
the saddle tanks - i was hoping to use them instead of the wing tank , and then use the wing tank for smoke ,this way keep the fuel all in a closed system, and notworry about joing each time i take apart the wing - but not sure if to do this , any comments ?
thanks guys
#2150
Izzy
The only reference is to have a balsa packer while the front retainer mounts are glued. This allows a small amount of fore/aft movement as the tank will expand over use and filling and if you have no gap to start with you will strain the tank!
It does not need 3mm, 1.5 to 2mm is OK.
I don't have the tanks held in any of my three Flash models, there is a tiny amount of free movement once you have had fuel in it. You could put some foam or small section of Velcro, but I don't think its needed.
Yes if you use the saddle tanks you won't have to split the fuel system...but it's no problem as the wing tank is always empty when the wing comes off and you purge/fill the lines each time you fill it.
Regards
Dave
Regards
Dave
