If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 88 of 223 FirstFirst ... 3878868788899098138188 ... LastLast
Results 2,176 to 2,200 of 5574
  1. #2176
    husafreak's Avatar
    Join Date
    Dec 2004
    Livermore, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: C-ARF Ultra Flash build Thread + Video
    Just wanted to drop in and say hi. I am beginning my research so I can purchase an Ultra Flash and make good choices. Ali already made some recommendations for me concerning motor choices, but I narrowed it down to somewhere between a Jetcat P100 to P140 will do it I think. I want a smoke system for sure. So I will go back and read the whole thread but my reasons for choosing the Ultra Flash are great aerobatic performance, reasonable size, economical, tough, popular, and I didn't want to deal with a scale jet for my first turbine. BTW the Pinnacle Jet colors are awesome! That is my only problem with the Flash, ugly (to me) color schemes
  2. #2177
    InboundLZ's Avatar
    Join Date
    Oct 2004
    Las Vegas, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    To the two guys that lost their Flashes, I lost mine a week or so back so I feel your pain.... It was a mid-air between myself and my flying buddy...he lost his Ultra Flash too! Was a very expensive morning! I had 381 flights on my flash over the last 18 months and she was a great ship...I will be replacing her as soon as I am able....I am seriously considering doing mine up like Pinnacle's cammo scheme when I do....
    Dave Bottita
    Jet Cat Factory Pilot
    JR America Team Member
    Smart-Fly
  3. #2178
    PaulD's Avatar
    Join Date
    Apr 2002
    Coquitlam, B.C., CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: InboundLZ
    Sorry to hear about the mid-air loss(es).
    I gotta say though, it would take me 5 or more years to put that many flights on any airframe. We just don't have the weather or the facilities to support this. So try to consider yourself lucky!
    PaulD
    If it\'\'s too LOUD - You\'\'re too OLD
    Www.wircsrc.com
    MAAC Jet Committee
  4. #2179
    Join Date
    Apr 2003
    REHOVOT, ISRAEL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    OK after breaking my head on this , i just cant find a solution , so anyone jump in
    setting up the flaps is a PITA , i know its been discussed somewhere on page 56 , but i cant get the servo to sit without stress /slight binding at no flap position
    see pics - the flap without any linkage of any sort sits aprox 10mm down flap ( even when wing is upside down , the flap itself wont drop under its own weight ) if i push down on it , cant find anything binding it , but it just pushes itself back up ( when upside down )
    this is true for both wings ( left and right) ,
    did anyone else have the same issue ?
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1816547   Click image for larger version.
  5. #2180
    Join Date
    Jun 2002
    Watford, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Izzy
    Could just be the new live hinge being under stress. By binding are you saying servo humm/buzz? or do you feel any catching/rubbing?
    My flap servos hum a little, but if you put a servo current meter on them (like Hanger 9 unit) the current is very low and in flight the load is taken off (so like measure the current with the wing upside down)
    How much force do you need to pull the flap square?
    At full flap does the lower wing surface show any movement? ie maybe a gentle clean on the lower hinge line with a 3mm dia round file to clean the glass more (most likely need either end of the flap)
    Dave
    Motors & Rotors. JetCat, Powerbox, Intairco, Behotec, CARF-models Rep. JR Propo for ever!, Jet 1A, MAP, Airtech Germany, Jet Tronics.
  6. #2181
    Join Date
    Apr 2003
    REHOVOT, ISRAEL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Dave Wilshere
    Izzy
    Dave
    Dave hi
    always there when i need you !!!! - thanks
    not much force to get it straight , but it always bounces back
    since i am working with the wing upside down , , the flap shuld want to straighten , so thats what bothered me is that it stays aprox 10-12mm down even under gravity (when upside down)
    also i looked everywhere to see if its touching anything , and all seems pretty right
    there is nothing to clean on the hinge line as the hingle line is on top, and the flap goes down
    the servo does humm , and if i releive the pressue say 4mm down flap , then it stops
  7. #2182
    stevekott's Avatar
    Join Date
    Nov 2006
    yorba linda, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    One Word ... WOW!! Gorgeous Model.
    ORIGINAL: Pinnacle Aviation
    All done apart from fitting a pilot
  8. #2183
    Join Date
    Jan 2005
    Brisbane, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I didnt like the UF flap servo mounting, so i mounted the aileron servo as per instructions then made up ply mounts to mount the Flap servos on the inside of the top wing skin... Perfect geometry, no slop. No problems.... Can get better access to the hatch with only disconnecting the aileron clevis.
  9. #2184
    Join Date
    Jun 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Izzy
    The hinge material is below the glass finish surface, the factory cut the flap out and clean the hinge line you see. If there is still tension across the surface the flap will bounce back. With the geometry we have the minor humming you have is unlikely to be an issue, but it would be nice to have no load. Have you tried taking the flap to 90 degrees+? If not a pass across the dark line on the lower surface with a small round file might help...
    Dave
  10. #2185
    IFlyEm35's Avatar
    Join Date
    Nov 2002
    Temecula, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey Dave,
    I have my throws set to your setup that you posted earlier in this thread. Are you running and flight modes or dual rates?
    Thanks!
    Mike
    I\'\'\'\'m in a jet!!! What could possibly go wrong?
  11. #2186
    IFlyEm35's Avatar
    Join Date
    Nov 2002
    Temecula, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well got everything pretty much done and was about to finish the canopy. That's when I realized the the dang guide tube is broken right inside the nose. [:@][:@][:@]
    Not sure how I am going to get to that without tearing a hole in the bottom of the fuse.
  12. #2187
    Join Date
    Jun 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Izzy
    I don't fly any rates or modes. I set the overal travel to give me what I want in roll rate and pitch response and I use Expo to smooth out the middle. My UF is super smooth full flap or no flap, elevator is smooth even with 40+% expo..and JR servos
    If you can't get your hand it to realign the tube before repair, you can just drill each end and replace the 3mm od tube.
    Dave
  13. #2188
    Join Date
    Dec 2001
    Mia, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Had the same problem when I remove the rod all the way out. I just push my hand inside the nose and straighten the tube while pushing the rod until it went through
    It's a hobby - keep it simple
  14. #2189
    tp777fo's Avatar
    Join Date
    Feb 2002
    Greer, SC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I slow down my servo speeds on aileron and elevator to help smooth out the inputs. Works nicely. Learned it from a pattern flyer.
    Tom Perry
    In Dog beers, I only had one!
  15. #2190
    Join Date
    Apr 2008
    Sydney, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: tp777fo
    Is the effect not the same as expo?
    Mav
    Love my Ultra Flash Merlin 140 and F22 Raptor P140 RX Multiplex Royal Pro 16
  16. #2191
    BaldEagel's Avatar
    Join Date
    Oct 2005
    Kent, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Mavrik!
    ORIGINAL: tp777fo
    Mav
    No its not slowing down the servo's slows the operating speed over the whole range of its movement, expo puts a curve on the control input to make it less sensitive around the center point, but the speed of operation remains the same, i.e. bang the stick over and the response is at the operational speed of the servo, if you slow the servo you will get to the end of the stick travel way before the servo does, not a good idea in my opinion.
    I can't imagine any pattern flyer using servo slow on the ailerons and elevator, but expo yes.
    Servo slow is for things like elevator trim when you put down the flaps or bringing in reflex ailerons.
    Mike
    My Gast is Flabered.
    No matter what anyone say's 100% is the maximum you can get.
    If you see a deleted post, my Avatar say's it all.
  17. #2192
    tp777fo's Avatar
    Join Date
    Feb 2002
    Greer, SC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Smoothes out the little twitches...try it..you'll like it. Guys comment about my flash all the time about how smooth it is.
    Tom Perry
  18. #2193
    IFlyEm35's Avatar
    Join Date
    Nov 2002
    Temecula, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    What speed are you running?
  19. #2194
    Join Date
    Jun 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    MMmmmm April 1st? Err nope...As I said before I have flown the same Hawks one with 8715 .11 sec servos and one with 8411 .19 sec servos on the same radio menu and it felt the same...guess I just have smooth moving fingers!
  20. #2195
    tp777fo's Avatar
    Join Date
    Feb 2002
    Greer, SC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    When I get home I will post the speed. Doing that work thing for a couple of days.
    Tom Perry
  21. #2196
    IFlyEm35's Avatar
    Join Date
    Nov 2002
    Temecula, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Got my maiden in today! For the most part it went good. Anytime you can bring the model home in one piece it's a victory right?
    I ended up needing 4 clicks of left aileron and 8 clicks of down elevator. Then it was hands off. In the air it was great. The only thing I felt was that the throw I have are way too slow.
    I am using Rudder - Low Rate - 35mm (1.3 in) / High Rate - 50mm (2 in)
    Elevator - Low Rate +/-6mm (0.25 in) / High Rate +/- 11mm (0.4 in)
    Aileron - Low Rate +/- 8mm (0.3 in) / High Rate +/- 12mm (0.5 in) dd
    Flap - Take Off - 28mm (1.1 in) / Landing - 75mm (3 in)
    Down Elevator - Take Off - 3.5mm (0.15 in) / Landing - 5.5mm (0.25 in)
    Crow (with Full Flap) - 5mm (0.2in)
    I will be increasing the ailerons and elevator for landing.
    The only other thing that needs to be addressed is HOLY CRAP THIS THING IS SQUIRRELLY ON THE GROUND. Aparently I am using WAY TOO MUCH nosewheel throw or I need to put a gyro on it. I don't have many planes that once you get them into the air the hard part is over! [X(]
    How much nosewheel deflection are you guys using for takeoff???
  22. #2197
    InboundLZ's Avatar
    Join Date
    Oct 2004
    Las Vegas, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    What nose tire/wheel you using? They way I had mine set up is with flaps up I had a good amount of nose steering travel, with flaps half or flu down I had a greatly reduced amount of travel. This will help but if you are using the stock hard rubber wheel on the nose you will see huge gains in controlability if you change the tire/wheel to something softer like a BVM tire.
    Dave Bottita
    Smart-Fly
  23. #2198
    IFlyEm35's Avatar
    Join Date
    Nov 2002
    Temecula, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: InboundLZ
    Good info. I am using the stock wheel. I have the throw reduced to 40% and 60 expo at takeoff flaps.
    Thanks!
  24. #2199
    IFlyEm35's Avatar
    Join Date
    Nov 2002
    Temecula, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Never did get around to posting some pics. So here they are:
  25. #2200
    Join Date
    Jun 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mike
    Keep an eye on your tygon to Festo joints, I don't like the mix of imperial and metric. I know it works, but it is not ideal. The tygon is too large and too soft to really work.
    I'm glad you went for that scheme though, don't see enough!!
    regards
    Dave
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
