The new Tornado sport jet
#2926
RE: The new Tornado sport jet
If you look at all of the pics that 747Junky posted, not one has a FOD screen on them. I'd like you to try and see how all of the turbines will fit after you add one. Iwill never run a turbine without one and is required for my JC warranty. For the record, my Rabbit works perfect with no stutters at all.air is also pulled in from the front nose wheel opening.
Dan
Dan
#2928
All you need is one of the raked back engine mounts sold by Modellbau UK, don't have to cut anything and can still use an FOD screen.
Mike
Mike
#2929
IN
I talked to Henry a couple of days ago. He said he's been flying one with the K100. Straight and level 250+ mph. Now that's what I call a jet trainer!
#2930
My Feedback: (48)
ORIGINAL: BaldEagel
Mike
Mike
Joe
#2931
Trouble is Joe not all of the new guys know the Tornado evolved from the Falcon 120, by the way how often have you flown yours at 250MPH.
Mike
Mike
#2932
ORIGINAL: BaldEagel
Mike
Mike
How many degrees down thrust are built-in the raked back mount sold by ModellbauUK? Thanks.
Azzam
#2933
ORIGINAL: joeflyer
That's right! The solution is simple, either buy or make a swepted back mount using the template I show in post #2864. I can't believe so many are carving up their fuses. This was first posted in the Falcon 120 thread over a year before Henry came up with the Tornado, and that's how a lot of the conversions were done. Henry should have copied it for the Tornado from the start.
Joe
ORIGINAL: BaldEagel
Mike
Mike
Joe
Thanks for the template. The problem I have is that Aluminium sheets with the right thickness and strength(?) are not available locally. Though, there is another solution that I am thinking about to bring the engine a little aft. Will post pics if I decided to go that rout.
Azzam
#2934
ORIGINAL: TUMBLER
i squeezed the fod aroud the starter motor so it was smaller and fit better.
Be careful the cable and fuel line going to your engine are rubbing against the sharp hacked-fuse edges.
Azzam
#2935
My Feedback: (13)
NJ
Thanks. Yeah I keep meaning to put something over it but never seem to think of it when's till the jet is at the field and there is nothing I can do haha.
ORIGINAL: phantom_najd
Hi Tumbler,
Azzam
ORIGINAL: TUMBLER
Azzam
#2936
My Feedback: (23)
Like I said earlier I didn't want to cut the fuse that much but not all of us fly off of paved runways so I want to leave the screen on, and I ffeel there is going to be enough air flow. When Modellbau sells the complete package kit, retracts, and engine they could ask if you are mounting with
or without the fod screen and supply the right mount. Just my opinion.
#2937
Azzam
I think its about 5 degs.
Patyak
This airframe originally was not designed for turbine operation and has evolved into such, Joeflyer especially and myself carried out the initial conversions, but instructions for this where never available, the thread detailing this is very long and laborious to get through, but does detail the evolution of this airframe.
As already posted the raked back mount supplied by Modellbau UK allows the fitting of the FOD screen, I also fly from a grass field and as you say a FOD is essential.
Mike
Patyak
Mike
#2938
ORIGINAL: patyak
This mount was probably for a smaller turbine, but even then I still ranked my mount to the rear to give better clearance for the P60. So I think it would be better if the kit mount was not as straight.
PS If you have no photo software, you can view your pics in windows explorer, right click on the picture, and you can then rotate them the correct way up.
#2939
I agree that FOD screens are cheap insurance and if you have one, use it (as long as the manufacturer says that it is OK for that turb). But I flew A LOT from 1999 thru 2004 and then have flown sporadically since and I never used a FOD screen and I never had an issue. Probably 70% of my flying was off of grass runways.
What scares me more than potential FOD from the outside of the plane is crap coming loose on the inside in a non-ducted installation or where you cut a big chunk out of the aft end of that Tornado fuse. In that case, don't worry too much about a rock getting kicked up (ain't gonna happen unless you fly off of gravel). Worry about a piece of wood coming off the interior.
#2940
This bolded below is not accurate at all. The K80 and K100 are in fact the same size, as they are the same turbine with internal modifications. The P80(se) is bigger than the Kingtechs. However, the rabbit 100 is way smaller than all of them. Here is my rabbit 100 next to my old k80. The rabbit about the same size as a P60 but with 22+ lbs of thrust. But your point of hacking the fuse is right on.
ORIGINAL: 747junky
Ok dont kill the messenger but what in the world are you guys doing hacking up the plane the way you are doing, that is crazy. There have been K80 installed on this airframe hundreds of times as well as K100G ( Which are the same size as the K80, Rabbit 100, and even P80 and you never have to hack the hell out of the fuse like that.
Like Dr. Honda said never stick the engine inlet into the fuse I bet you will have problems. Not sure why it is so difficult to mount this engine? it is a breeze I have attached a few pictures from this same forum with various different engine installed none of them having to be hacked like that.
#2941
Hi all,
I am in the process of building my V3.
I would like to know what is the best way to fit the fuel tank.
Any advice and pictures would be appreciated as usual.
Ulrich
Ulrich
#2942
The rear servo support former inside the fus needs to be removed, or cut down to allow the tank to be positioned, flex the fus outwards and the glue will come away from the fus, unless it has been reinforced with Hysol, in which case you may have to cut it away to allow the tank to pass.
Mike
Mike
#2944
we had a tornado here, biggest heap of crap there was, booms flew off on the 4th flight. Decided to make my own plug and complete composite aircraft.
#2945
Banned
ORIGINAL: NZjet
#2946
ORIGINAL: NZjet
#2947
That is exactly how the modified/improved Falcon 120 should have been built, although I am curious with yours how you intend to bolt on the turbine.
By the way if your Booms flew off then you probably never re glued the captive nut blocks in the booms, I agree you shouldnt have to especially on the "modified" Tornado, but everything needs to be re-glued as the glue they use in china is made from flour and water
#2948
I thought that too, not only the turbine mount, but it does not look as though it has split flaps either, are they still to be cut out and hinged? or are they live hinged and not freed up yet?
Mike
Mike
#2950
Shame you can't quite see the dia of the prop, but its x 10 looking at the pic, so as you say may be a bit small, perhaps he will come back onto the thread and explain??
Mike
Mike
