The new Tornado sport jet
Reply
Old 10-11-2011, 11:08 AM
  #1576
r 3
r 3's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: The new Tornado sport jet
r 3 is offline
Old 10-12-2011, 01:50 AM
  #1577
Dieselman1220
Dieselman1220's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ive started putting my tornado together, I remember someone in this thread saying an AMT 180 would not fit. All I had to do to mine was notch the triangle stock brace, alot easier than what some other people are doing.
heres a few pics of mine,[img][/img] not bad for an $800 airplane and $700 turbine.
Dieselman1220 is offline
Old 10-12-2011, 01:52 AM
  #1578
Dieselman1220
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
and another pic
Old 10-12-2011, 02:48 AM
  #1579
rcguy!
rcguy!'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
R3
WOW! Ya puttin' in a P200? That alum mount is way too "stout" Bend some 1.5mm alli and be done with it.
Dave
rcguy! is offline
Old 10-12-2011, 08:57 AM
  #1580
r 3
r 3's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
r 3 is offline
Old 10-18-2011, 07:13 AM
  #1581
r 3
r 3's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
r 3 is offline
Old 10-18-2011, 08:50 AM
  #1582
joeflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
r 3,
I was concerned after looking at your pictures in post #1548. It looks like you have taken a notoriously weak section of the fuse and made it significantly weaker. The motor mount section of the fuse is poorly engineered and weak enough that it will crack at the 90 degree corner at the front of the shelf where the mount gets attached. Unfortunately the wood inside the shelf stops right at that corner resulting in the fiberglass sides being the only thing holding it up. If you read the Falcon 120 thread you'll see that a number of guys had it crack there. My Falcon 120 was fine for about 35 flights, then the first time I bounced a landing it cracked there. It's a shame that Henry copied that poor design instead of fixing it for the Tornado. That piece of wood he supplies is an attempt to address the issue, but I doubt it's very effective.
If you read the Falcon 120 thread you'll see that a number of us have reinforced that area with carbon fiber rods or hardwood to span that weak corner. After mine cracked I added 1/2 X 3/4 inch hardwood that extends about 6 inches into the fuse and is firmly attached to formers I added back there. I suggest that you do something similar to yours. See pictures.
Additionally this plane is naturally very nose heavy and it's best to mount the engine and all equipment as far rearward as possible. If you leave the engine as in your pictures you will most likely have to put your batteries and some additional weight in the rear to balance it. You can see from my pictures that my Wren SS is mounted further back than yours. My batteries are in the mid cockpit area to achieve balance on the recommended CG.
Just trying to be helpful, not critical.
Joe
ID:	1675926   Click image for larger version
ID:	1675927   Click image for larger version
joeflyer is online now
Old 10-18-2011, 09:45 AM
  #1583
r 3
r 3's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
r 3 is offline
Old 10-18-2011, 09:51 AM
  #1584
megafly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Look what I did in mine.
And the battries inside.
But I changed my batteries a litle to rear, it was a bit noose heavy.
megafly is offline
Old 10-18-2011, 10:56 AM
  #1585
joeflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You won't crack it pulling high G's. On a hard landing the weight of the engine coming down on the back of the fuse is what will cause it to crack. You really need something that spans that weak corner and lets the beefier part of the rear fuse support the engine weight.
Good luck,
Joe
Old 10-18-2011, 11:35 AM
  #1586
Modellbau USA
Modellbau USA's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well first of all the motor mount is heavily reinforced and will not break, trust I have tried. As for the modifications that have been done to the tail I really don't like what I see. It looks like that will break off. Just my two cents.
As for the wing and dihedral being wrong and so on. Well all I can tell you it's builders error. I am 100% sure of it. I have had about 5 people do exactly what you are describing and have exactly the same problem. 2 listened and fixed there problem and the others swore to me the airplane was wrong. So I will extended the same thing to you as I did to them. Send the plane back to me if when we get it its wrong I will pay for all the shipping and give you $100. If we put it together and the airplane fits fine you pay for all the shipping and you give me 100% for wasting my time. We have made 400+ of the tornados on the last batch and if one is wrong all of them are bad. That's how mass production works. If you would like please call me and I can explain to you what to do.
Modellbau USA is offline
Old 10-18-2011, 12:09 PM
  #1587
dmscpu
dmscpu's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Modellbau USA
Henry,
I found if you use the K80 and a FOD screen the turbine will not fit on the mount, so some sort of cutout is required or raise the turbine high on the mount.
So I cut mine and plan on filling the void with epoxy and fiberglass but in a concave shape as to fill the hole and add strength back in. On that note
What type ( Enamel ) of paint and color? so that I may match it. Otherwise I guess I can use black.
Mike
dmscpu is offline
Old 10-18-2011, 01:42 PM
  #1588
Boomerang1
Boomerang1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I converted a smaller Bobcat 50 to turbine & it had the same weak spot on the engine shelf & it had started to crack from the previous owner's hard landings. I could not see any way to fit reinforcing through the piece of timber in the shelf so I fitted aluminium supports under the fuselage. - John.
Boomerang1 is offline
Old 10-18-2011, 11:41 PM
  #1589
ausfester
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does anyone know the part number for the springair struts?
My rear left strut needs replacing.
Henry can you provide replacements or should we speak with SpringAir directly?
If anyone has a set or spare please let me know as ild be very interested in purchasing one second hand or new
ausfester is offline
Old 10-21-2011, 03:05 PM
  #1590
Dblex
Dblex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok guys...
My Hitec 225's are about 1/4in too tall in the elevator servo slots......
Lets see your mods!
Dblex is offline
Old 10-21-2011, 03:23 PM
  #1591
dmscpu
dmscpu's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Dblex
Ok guys...
Lets see your mods!
Uhh 1/4" plywood......
That's what I used and use the screws that came with the servos.
Mike
dmscpu is offline
Old 10-21-2011, 03:25 PM
  #1592
Boomerang1
Boomerang1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If your servos are as big as your font I'm not surprised they won't fit! - John.
Old 10-21-2011, 03:29 PM
  #1593
Dblex
Dblex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thats what she said John....LMAO
I figured I would spice things up on a Friday, finally got time to start up again on my build! And my blackberry isnt blowing up with Hate posts! So Party time to build!
Dblex is offline
Old 10-21-2011, 03:31 PM
  #1594
Jetfan20
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Dblex
I Promise that's not what she said...lol thats what they make us think. Have fun building!!!! Which turbine are you running in yours?
Jetfan20 is offline
Old 10-21-2011, 06:30 PM
  #1595
Dieselman1220
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: dmscpu
Quote:
ORIGINAL: Dblex
Ok guys...
Lets see your mods!
Uhh 1/4'' plywood......
Mike
+1 I used 5645s on my rudders
Old 10-22-2011, 12:43 AM
  #1596
r 3
r 3's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
r 3 is offline
Old 10-22-2011, 08:42 AM
  #1597
r 3
r 3's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
r 3 is offline
Old 10-22-2011, 09:46 AM
  #1598
Dieselman1220
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Another successful Tornado maiden today. Mine is powered by an AMT mercury (AMT180) A slightly heavier and thirstier engine than the P70s and K80s most people are using. Even with my dual 2700MAH 6.0V NIMH packs and 2200 lipo in front of the tray she was still
a little tail heavy. she took 6 oz to balance out at the 12.5" recomended CG however she seemed a little nose heavy in flight , needed quite a bit of up trim and took about a quarter stick down to hold inverted level. Where is everyone else balancing theirs? I may take 2 oz out.
Anyway Fired up my airstart Mercury ran her up and and the runway a few times checking steering and brakes lined her up took a deep breath and nailed the throttle she was off in probably 100ft. She needed about 6-8 clicks of up trim and maybe 2 or 3 of right aileron
and she was flying hands off. Mine seemed to be dancing around a bit but that may have been from the 15-20MPH breeze today. first landing came in I thought i was pretty slow enough i went to give her just a bit of a flare right as she touch down and she hopped up about 3ft in the air and went another 30-40ft before she settled down again. got on the brakes and she was stopped within 100ft.
Second flight I rung her out a little more really a great flying plane did some slow flight, saw how slow she could get but when I came in for landing I got a little to slow and stalled her about 5 ft off the deck. she dropped flat and ripped out the left main. (I was expecting to rip the gear out anyway) to give an idea how slow I was she probably only skid about 6-8ft before stopping. So yes my fault bad landing, however upon inspection the rear rail broke out cleanly very little glue and it looks like they used CA to glue it. Anyway Im not surprised I was expecting it to happen typical chineese ARF or S American whatever I could care less where its built. Its still an amazing value of an airplane, and Henrys great support is a great bonus.
Speaking of value here is my total investment
Airframe/Struts $815
Used AMT 180-I payed $700
Misc parts and accessories $60 and thats a High estimate
Servos were all 5645s and
5625s I had already along with
Savox servos for the elevator I
did have to buy however the total
for servos if new is $500
BVM smooth Stop $100
Batteries $75
Grand total $2250
Amazing Value for this kind of Jet I went over my Budget by $250 I was really trying to keep it under $2k I guess technically i did since I only had to buy 2 servos which cost me $120 I had the rest of them lying around.
I guess I forgot to add the RX also a Futaba 6014HS which is $200 but I had it laying around also.
So my budget beater jet is a "great success" I have a feeling there will be several people at my club looking into jets now knowing you dont have to trade in your car to buy one.
GREAT JOB Modellbau and Henry what your doing is fantastic thanks for thinking about us "budget" jet pilots
Old 10-23-2011, 03:00 PM
  #1599
lenhard2007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is my first jet build so enjoy.
Any suggestion greatly helps, but please no bashing.http://www.youtube.com/watch?v=ft3aOHBRGCE
lenhard2007 is offline
Old 10-23-2011, 03:47 PM
  #1600
Dieselman1220
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: lenhard2007
Nice vid man, the horns are made out of a material called g-10 very strong very similar to carbon fiber.
I've heard to not use ball links on them though due to the possible twisting force that can weaken them over time.
Not sure though they seem plenty strong to handle it.
I used 4-40 full threaded rods also then I put a carbon fiber rod with a nut on each end to capture it, probably overkill
But defiantly much much stiffer and looks alot prettier too. I haven't noticed any issues with my tank moving I did have to trim the formers also. Mine is squeezed tightly between the formers and spar, I almost didn't even shoe goo it down but I figured I better.
Looking good bro, nothing too it, it's just an airplane with your typical chinese ARF issues.
Also I would just reinforce the gear blocks from the get go. I used hysol where I could to reinforce it also and I still ripped one out.
Not enough glue on the top side of the block which you cannot get to without removing the sheeting, and then the blocks are just a cheap soft balsa.
Reply
Display Modes
