If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 65 of 146 FirstFirst ... 1555636465666775115 ... LastLast
Results 1,601 to 1,625 of 3638
  1. #1601
    Countryboy's Avatar
    Join Date
    Dec 2001
    Lawrenceburg, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: The new Tornado sport jet
    ORIGINAL: lenhard2007
    This is my first jet build so enjoy.
    Any suggestion greatly helps, but please no bashing.http://www.youtube.com/watch?v=ft3aOHBRGCE
    "Tip"
    Find a large zip-tie and cut the one end off and shrink wrap it to the inside edge of the steering cables. When the cables go slack, the zip-tie will spread the cables and keep the nose gear from getting tangled.
    Attached Images Attached Images
  2. #1602
    Join Date
    Aug 2010
    arnold, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    well i guess ill just replace the wood blocks then with hardwood. rather do it now verse it do it on landing. Thank you
  3. #1603
    Dieselman1220's Avatar
    Join Date
    Feb 2004
    McAllen, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yea I was thinking the same thing, but learn from my mistake
    Joseph K
  4. #1604
    r 3's Avatar
    Join Date
    Nov 2008
    ABZ, Scotland
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Americans tell you that if you want to identify tartans, it's easy – you simply look under the kilt, and if it's a quarter-pounder , you know it's a McDonald's.
  5. #1605
    Join Date
    Aug 2010
    arnold, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    has anybody else weighted their jet by just placing it on a scale for the front nose to be 1 1/2 pounds? i like this idea just dont know if i sould do cg also, im coming in at 1.8 pds but im gonna move my ecu battery, just really dont want to because i dont have the room
  6. #1606
    Join Date
    Jul 2005
    Riyadh, SAUDI ARABIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    has anybody else weighted their jet by just placing it on a scale for the front nose to be 1 1/2 pounds? i like this idea just dont knowΒ* if i sould do cg also, im coming in at 1.8 pds but im gonna move my ecu battery, just really dont want to because i dont have the room
    I did and I have 21 flights on my plane. the last two flights I had to move the 2 x 2200 LiFe batteries around 10 cm forward because I couldn't put them back in their original location in the field (and I had no time to try hard ) and man I am glad I did that, it flies much better now. So my advise is to level all gears (the nose being on the scale) and place everything inside for the scale to read slightly over 1.5 lbs.
    Azzam
  7. #1607
    Modellbau USA's Avatar
    Join Date
    Jul 2009
    Ft. Lauderdale, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    *****PLEASE READ THE ADDENDUM BELOW FOR THE BOOMS OF THE TORNADO. *****
    The Boom addendum can also be found on our website in the download section.
    Attached Files Attached Files
    Henry Castellanos
    www.ModellbauUSA.com
    305-607-7554
  8. #1608
    Join Date
    Apr 2006
    Enterprise, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i think I'll go ahead and reinforce mine too even though its P-60SE and i don't snatch her around.
    Morgan Fuels / JetCat / KingTech
  9. #1609
    BaldEagel's Avatar
    Join Date
    Oct 2005
    Kent, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If you are going to reinforce these areas I would recommend using chopped glass fibre rather than micro ballons, much stronger for a over 15lb turbine.
    Mike
    My Gast is Flabered.
    No matter what anyone say's 100% is the maximum you can get.
    If you see a deleted post, my Avatar say's it all.
  10. #1610
    Join Date
    Dec 2001
    Plymouth, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: BaldEagel
    Mike
    Agreed, micro ballons are just filler and don't add strength. Glass fiber on the other hand does add strength.
    A better way is to cut a wooden block to just fit into the space below the t-nut and drill a hole in it for the bolt to go through, epoxy it in place and sand it even with the bottom of the boom. That's how I did mine. Besides adding more strength that will also prevent damage if you over tighten the boom bolts. A friend lost his Falcon 120 right after tightening the bolts. The post mortem revealed that he had cracked the small piece of plywood that the t-nut is mounted on.
    Joe
  11. #1611
    Xairflyer's Avatar
    Join Date
    Dec 2002
    Co. Donegal, IRELAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That was a standard thing to do on the Falcon 120, I even had to do it on the smaller Bobcat, I'm surprised this was still the same setup as it was always a weak point, I added extra pieces of wood on mine as well.
    www.letterkennymodelflyingclub.com
    www.jmaireland.com
  12. #1612
    Join Date
    Jul 2009
    Ft. Lauderdale, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    This is not a weak point or a flaw. We reinforced this area enough. The reason I put this addendum out is because after 280 flights on my factory demo. That we take to all the shows and everybody flies a beats up with snap rolls and high G turns at full throttle came loose on the inspection I did after this weekends fun. All I suggest is making sure it is glued properly that's all. Please all wanting to re-engineer an airplane that they don't have I ask you to please keep your comments to your self. We have sold over 450 kits this year and brought over 200 new jet pilots to our club of turbine pilots around the world. So for the sake of those who don't have much building experience let's keep this simple. The next models will be taken care of in a totally new way so let's keep this simple for the new guys thanks.
    Henry Castellanos
    305-607-7554
  13. #1613
    Xairflyer's Avatar
    Join Date
    Dec 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Henry you are just unbelievable at times, all any of us have said is what we had already done to fix the problem, check out the Falcon 120 and nitro planes bobcat threads, there are lots of posts and pictures with exactly the same potential problem, because the ply plate that holds the captive nut, locates into the booms the exact same way, then obviously the fix is the same.
    www.jmaireland.com
  14. #1614
    Join Date
    Jul 2009
    Ft. Lauderdale, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Actually it is different but I am not here to discuss how. All your ideas are great and will do the job. The addendum only requires you to add extra glue and thats all but if you want to go above and beyond thats is upto the builder.
    Henry Castellanos
    305-607-7554
  15. #1615
    r 3's Avatar
    Join Date
    Nov 2008
    ABZ, Scotland
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
  16. #1616
    Xairflyer's Avatar
    Join Date
    Dec 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    A picture says a thousand words, nothing more needs to be said.
    www.jmaireland.com
  17. #1617
    BaldEagel's Avatar
    Join Date
    Oct 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Can someone tell me what one is the.................Oh forget it.
    Mike
  18. #1618
    Dr Honda's Avatar
    Join Date
    Apr 2005
    Latrobe, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Xairflyer
    Hey now... let's not point fingers, and say they are the same. The Tornado booms are clearly coverd in gray. (lol) [sm=lol.gif]
    Tony
  19. #1619
    r 3's Avatar
    Join Date
    Nov 2008
    ABZ, Scotland
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
  20. #1620
    Join Date
    Apr 2006
    Enterprise, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: r 3
    ...............I did start to fit the tank that’s comes with the tornado however after a hour f-ing about in side the fuselage to get a good fit lost interest so water bottle will be fitted.
    it's really quiet simple, you stick the fuel tank in it's location..........insert the wing tubes and it's there, can't get much easier then that.
  21. #1621
    Join Date
    Jul 2009
    Ft. Lauderdale, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sir you can do as your wish with your model, but like I have mentioned in the addendum, YOU HAVE TO GLUE the STAB. It's not optional if you choose not to do that then it's your responsibility if you loose your plane. We will not help in anyway. The airplane structurally is made to be built the way the instructions say. We have tested it thoroughly and I suggest you built it the way we say.
    Henry Castellanos
    305-607-7554
  22. #1622
    r 3's Avatar
    Join Date
    Nov 2008
    ABZ, Scotland
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
  23. #1623
    Join Date
    Jul 2004
    England, , UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
  24. #1624
    Join Date
    Jul 2009
    Ft. Lauderdale, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just a few pics of a some of our new turbine folks down south in Brazil.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1681655   Click image for larger version.
ID:	1681656   Click image for larger version.
ID:	1681657   Click image for larger version.
ID:	1681658   Click image for larger version.
    Henry Castellanos
    305-607-7554
  25. #1625
    Join Date
    Jun 2004
    villahermosa, MEXICO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    This past weekend I witness a maiden of a first batch Tornado. What a great plane for the money, it was powered by a JC Bee and it has more than enough power. I want one for christmas, but now with the Hurricane coming, I don't know what to do.
    Vic
    SM Viper 2M with JC Cheetah/SM F-86 with JC Rabbit 100
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
