If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 7 of 146 FirstFirst ... 567891757107 ... LastLast
Results 151 to 175 of 3638
  1. #151
    Pepperpete's Avatar
    Join Date
    Sep 2006
    Grande Prairie, AB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: The new Tornado sport jet
    That's really not bad for quality trailing links. We need to see exactly what is going to be sold for the Tornado for 200 bucks. I don't mind putting a bit extra money in for grass flying safety.
  2. #152
    RCISFUN's Avatar
    Join Date
    Apr 2002
    Erie, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Pepperpete
    Exactly...that's everything except the tubing, valve, and a tank
    Sandor Kruise aka"Digitec"is great to deal with, I have bought a few sets from him...great service!
    Rich
    Jeti USA Flight Team - DS-16, Xtreme Arf, Fei Bao Jets, Jet Central: SE Rhino 200, Cheetah, & Super Eagle owner
  3. #153
    Modellbau USA's Avatar
    Join Date
    Jul 2009
    Ft. Lauderdale, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That is a great price, I can offer you guys the kit with out retracts for $395.00 if anybody would like that please let me know. I am here to help!!!
    Henry Castellanos
    www.ModellbauUSA.com
    305-607-7554
  4. #154
    RCISFUN's Avatar
    Join Date
    Apr 2002
    Erie, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Modellbau USA
    That is a great price, I can offer you guys the kit with out retracts for $395.00 if anybody would like that please let me know.Β* I am here to help!!!
    Now you're Talking!!!
    I assume that if they fit the Falcon 120 they should fit this one.....correct
    Rich
  5. #155
    Join Date
    Jul 2009
    Ft. Lauderdale, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    well I am about 90% sure, but my spyde sense tells me yes.
    Henry Castellanos
    305-607-7554
  6. #156
    Join Date
    Jan 2003
    Winamac, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    At this time we are not because, it was designed around the custom spring air retracts and we do not want people to start cutting away on the gear blocks to squeeze in bigger gear and weakening the structure.
    Henry,
    Glad to see you have changed your mind from my original question and decided to offer the plane without retracts. Thank You!!
    Jim Widner
    Falcon Models
    Custom Building Service and Model Supply
    Team Hitec, Team SebArt RC
  7. #157
    Join Date
    Jul 2009
    Ft. Lauderdale, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I still am concerned about people cutting away at the gear blocks and hopfully people will think before they do that. But I said that to say this, I am here for your guys so what ever Ican do to make things better for you Iwill do my best to do.
    Henry Castellanos
    305-607-7554
  8. #158
    Join Date
    Jul 2005
    Sun Valley, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I like the smoke tube......lol Can't wait to see the combo price with the turbine if it's as low as you lead on.
    Back Roads Outlaws Revver #165
  9. #159
    Pepperpete's Avatar
    Join Date
    Sep 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: CowboyLifesaver
    It's going to have to be pretty dang good IMO. You can get a KingTech K-80E turbine with 19 pounds of blow for $1725 right now from Dreamworks. Add in the Tornado and you are around $2200. I've seen the K80 run and talked to a ton of people who own and use them and they seem very solid and reliable. In comparison the P-60SE goes for around $2099 from Dreamworks. Add the Tornado and it would be $2574 for 6 pounds LESS thrust and a very inefficient fuel hunger. So unless this deal is around the $2200 mark or lower, it might be a tough sell. The plane price is still outstanding though.
    I hope this combo deal is awe-inspiring.
  10. #160
    Pepperpete's Avatar
    Join Date
    Sep 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That is FANTASTIC! I already have quality gear to go into the Tornado and this just made it better. E-mail inbound!
  11. #161
    BaldEagel's Avatar
    Join Date
    Oct 2005
    Kent, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The tail of the plane is all one piece. Β*The elevator is designed to be glued to the booms, so all you have to do is unscrew the 4 bolts for the booms and that is one complete piece. As for the airfoil it is a semi-symmetrical airfoil that has been modified to have good slow speed characteristics as well as high speed. Β*That is what makes this jet so great, it looks good and fly's even betterΒ*
    Not an original suggestion I think it was John Veasy who did this on his Falcon first, but when you take the booms and tail off, bolt a spreader bar between the booms to prevent transport damage pulling them apart and breaking the glue joint on the tailplane.
    The Falcon has a bottom hatch to get too the wing holding bolts from inside, I assume the Tornado is the same, this was very difficult with the tank in the way in the Falcon, I modded my Falcon with a slot and tube in the wing to allow a hex key to get to a bolt permenatly fixed in the root rib and put the T nut inside the fus, as the CARF Rookie, much easier to rig on the field, also as there are four servo leads in each wing I used a PC serial plug and socket to automatically connect all the cables in the wing root, this is all fit out and personnal preferance though.
    Can't wait to see the finnished offering.
    Mike
    My Gast is Flabered.
    No matter what anyone say's 100% is the maximum you can get.
    If you see a deleted post, my Avatar say's it all.
  12. #162
    Join Date
    Jul 2009
    Ft. Lauderdale, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I really suggest not making any decision on how to secure the wing to the plane since we have made changes. The wing is held by 2 screws not just 1 and some other minor things that will be shown in the instructions
    Henry Castellanos
    305-607-7554
  13. #163
    Join Date
    Nov 2003
    MT SHASTA, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Henry,
    I for one am pleased to hear the Tornado will ship with Spring Air retracts. I have 4 sets in variuos planes and have never had problem in five years, nor have a ever lost a plane to belly landings.... Thanks
    Mike
  14. #164
    Join Date
    Sep 2010
    Brooklyn, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Same here Henry thank you for the work you guys have done and all the quick response and customer service you guys are providing. Also I just received my P120 thanks for the great deal
  15. #165
    Join Date
    Oct 2010
    Boston, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks from all the boys up here in Mass.
  16. #166
    Join Date
    Oct 2010
    Boston, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I found these pics on Henry's Aermacchi MB339 thread and thought these pictures were awesome, he is nuts
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1527742   Click image for larger version.
  17. #167
    rorrock's Avatar
    Join Date
    Dec 2006
    Springfield LakesQLD, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Could you imagine seeing that in your rear vision mirror.....
    Jet Models Australia - Swiwin Turbines, T1 Models, C&C Models.
    HOTT Turbine Air Module - Under development
  18. #168
    Join Date
    Oct 2010
    Boston, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Apparently Henry did an awesome demo in the black hawk at a RC jet event in florida from what I read in the thread were I got the pictures
  19. #169
    Join Date
    Jul 2009
    Ft. Lauderdale, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well guys I would not say im nuts just a little bit of an adrenaline junky LOL.
    Henry Castellanos
    305-607-7554
  20. #170
    rorrock's Avatar
    Join Date
    Dec 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I wonder what was going through the mind of the guy in the SUV.
  21. #171
    Join Date
    Jul 2009
    Ft. Lauderdale, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well anyway back to the Tornado below is a picture of the fuselage right after construction you can see that the fuel tank fits perfectly in the fuse. We are working on a smoke tank that will fit underneath the front of the main tank. The center servo is for the nose wheel steering standard size and the left and right are gear and brake valve both standard size. You can add small piece of hard wood if you want to make it for a smaller servo. Also I have included a picture of the inside rear of the fuselage you can see that all formers are very well glued and that I have drilled a whole in the formers so you can fit the fuel line for the smoke system and brass tubing leading out the back fuse.
ID:	1527868   Click image for larger version.
    Henry Castellanos
    305-607-7554
  22. #172
    Join Date
    Jul 2009
    Ft. Lauderdale, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I am not sure what the guys were thinking but it sure was cool.
    Henry Castellanos
    305-607-7554
  23. #173
    Join Date
    Jul 2009
    Ft. Lauderdale, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I wanted to announceto all that we decided change the struts package offered for this airplane. We have worked overtime in the last week or so and we will have the trailing link struts for the TORNADO packaged up with the wheels and brakes instead of the straight off set struts that we originally had. The reason for the change was for the large number of emails requesting a trailing link. Like I have said before you guys ask and we will do our best to get it done. The price of the package will not be very much more than the original $200. Which is well under the trailing link struts price that was stated on the previous post's. Guys I encourage ideas and I will do my best to make it happen. Have a great day
    Henry Castellanos
    305-607-7554
  24. #174
    BaldEagel's Avatar
    Join Date
    Oct 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Now that is what I call progress, someone listening to the customers, I suppose I am going to have to buy one now. LOL
    Mike
  25. #175
    Join Date
    Sep 2003
    colorado springs, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    DO this mean a delay in the first shipment?
    Rod
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
