Can a Byron Mig 15 be converted Two Turbine?
My Feedback: (16)
OH
I have a NIB Byron Mig 15 that I am considering installing a 12-14 lb turbine in. My search has come up empty on anyone doing so. Has anyone taken on such a project that you know of??
RE: Can a Byron Mig 15 be converted Two Turbine?
How is it possible that native English speaking people type so many mistakes in these words:
Two
Too
To
Field
Receiver
Transmitter
Turbine
Gauge
Definitely
It makes all this confusing to read...
Just an observation from the opposite side of the world with different languages...
TP.
Two
Too
To
Field
Receiver
Transmitter
Turbine
Gauge
Definitely
TP.
My Feedback: (41)
i have built many of these.. comes out real tail heavy.you will need to put two servoes ,one in each stab.rudder also. more tail weight.. not good.install turbine as far forward as possible.they fly great.. 16 lbs is the sweet spot. wing fairings on the fuse ,are not the same.. one side has 3 deg different angle [AOA] than the other. will cause a bad roll. flaps work super.
ORIGINAL: Ayrtonsenna
Dam it...I had a look in Babel fish, and there's no American to English [:-]
井 åš als vous gearbeitet αυτό fuori
rapptor: Wax your goat??
For such a simple question, this thread is making me piss myself laughing!!!
The popular thing to do with the older ICDF models is to convert them to electric rather than turbine. I know it's not what you have asked, but I have the byron F-16 and was tossing up the same thing. Everyone who had converted it TWO turbine said it ended up coming out too heavy.
Mine came out at 13lbs and I get about 14-15lbs thrust from the e-byrofan. get's off the grass no probs! the vid was taken before i installed the retracts. and i am now running 12s packs for evem more get up and go.
http://www.youtube.com/watch?v=3AQjtu-vw7E
Just another option which is cheaper than 2 turbines!
dave
Nice! I have read in a German mag about a dude who had 2 engines in a Mig15. But then it was something like 1/3 scale!
Aint photoshop fabuloustically entertaining!
Jonas
Jonas
Banned
OK....How about cadded plans for A B-45 tornado bomber? 100inch+ span...
for Ticketec.....what is the rundown on that byron edf setup....motor /controller. batteries, mounting?
That would be another way to go on the Byron Mig, and I do agree its great to have other OPTIONS!!!
I HAVE A 3RD GENERATION MIG THAT I AM PUTTING TOGETHER AND I WILL BE INSTALLING A JET CAT ,IT IS REALLY VERY SIMPLE,IT WOULD HELP IF YOU HAD THETURBIN SO YOU CAN BUILD THE MOUNTS ,I AM EITHER MAKEING MY OWN DOUBLE WALL EXHAUST TUBE OR I MAY BUY ONE FROM JET EAGLE ,I HAVE A F-16 TURBIN ALREADY AND IF YOU SEE THE INSTALLION IT SOON BECOMES CLEAR IT IS A NO BRAINER I CAN TELL YOU THIS,I ALSO CONSIDERED GOING ELECTRIC,THERE ARE SOME OUT THERE THAT ARE EXCEDEING 17 LBS THRUST,REALLY IMPRESSIVE I CERTANLY WILL NOT DO THAT DUCTED FAN THING USEING THE WAND AND ALL THAT NONSENSE HOPE THIS HELPS YOU SOME JOHN
