worth watching it / very fast!!
Use 1080 HD and at least the expand mode.
It´s NOT HD but better quality.
Have fun.
http://www.youtube.com/watch?v=S98-g_Zn_Aw
INFERNO + BEHOTEC JB 180 TURBINE,
5.2 KG + 1.6 KG kerosin, appropriate thrust.
2 x Futaba BLS155 Servos.
Wingspan: 1m
Length: 1.2 m
Have fun.
Wingspan: 1m
Length: 1.2 m
RE: worth watching it / very fast!!
ORIGINAL: SinCityJets
Well, there goes the speed record....
My Feedback: (22)
Not a contender for Shui's record. There was a delta called the Scout powered by a P160 a few years ago that was hitting I believe 366mph too, however, Shui's record is for the fastest "Conventionally configured turbine model aircraft". That means something with landing gear, internal engine, basically, something that could be a full scale jet.
These little Delta's are crazy fast though, and they're small! You need better than eyes of an eagle to follow those!
ORIGINAL: LGM Graphix
Not a contender for Shui's record. There was a delta called the Scout powered by a P160 a few years ago that was hitting I believe 366mph too, however, Shui's record is for the fastest ''Conventionally configured turbine model aircraft''. That means something with landing gear, internal engine, basically, something that could be a full scale jet.
That is correct. These deltas including hotspots have been doing these speeds for a few years now. But the world record is for conventional model aircraft.
Paul
Maybe I can attempt to make a new WR with my Tutor under the criterias: "RC turbine model aircraft with a straight low wing, side by side configuration and with a T-tail"??
No. A RC turbine speed record is a turbine speed record, and in my opinion the WR does not belong to Shui.
My Feedback: (29)
Now if someone wants to own the all out fastest turbine speed record all they have to do is fly faster than Shui in any jet and then jump through all the hoops, dot all the "i"s and cross all the "t"s to get a sanctioning body to put a speed record in their name.
ORIGINAL: SAP_2000
So everyone can make their own criterias for a speed record? And where does it say what criterias a ''Conventionally configured turbine model aircraft'' have to fulfill? Who sets the criterias?
Maybe I can attempt to make a new WR with my Tutor under the criterias: ''RC turbine model aircraft with a straight low wing, side by side configuration and with a T-tail''??
As far as RC airplanes go the Dynamic Soaring gliders do over 400 mph. These would have to carry the speed record for R/C in general. You have to classify the records though, otherwise you would have a car with 4 wheels competing with a rocket with two wheels for the land speed record. Not the same comparison.
PA
I think the guiness people were there for SHUI's record and if so they set the rules. Either way they are just models that go fast, no big deal.
Albert
Albert
ORIGINAL: as722
Albert
Albert
