TURBINE OIL
Reply
Old 11-13-2010, 09:08 AM
vpower
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: TURBINE OIL
*i am not trying to ruin this post but since its fuel related ima ask lol*(sry if i ruined to post)
where can i get the fuel for the turbine motor and what is it made of?(again sry if i ruined the post[sm=drowning.gif])
vpower is offline
Old 11-13-2010, 09:09 AM
gruntled
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
kerosene or Jet-A
gruntled is offline
Old 11-13-2010, 11:50 AM
vpower
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
both ^^
vpower is offline
Old 12-01-2010, 01:26 PM
Pegasus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
is this the right stuff?
ID:	1528847   Click image for larger version
Pegasus is offline
Old 12-01-2010, 03:59 PM
hooker53
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pegasus, Yes-Thats what I been using. Good stuff. Roy
hooker53 is offline
Old 12-01-2010, 04:05 PM
  #31
Pegasus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I will give it a go, thanks
Pegasus is offline
Old 12-01-2010, 05:47 PM
  #32
rcjetsaok
rcjetsaok's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
IIs anybody useing the Mobil DTE 24 Light in AMT engines????
Danno
rcjetsaok is online now
Old 12-02-2010, 08:41 AM
  #33
asimace
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys,
in Italy I managed to find this 20 litre can.
It's marked Mobli DTE Oil Light and not Mobil DTE 24...
Is it the same stuff?
Thanks, Mauri
asimace is offline
Old 12-17-2010, 08:11 PM
  #34
chad_voelkel
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What are you guys ratio are you guys mixing at. I know it is a stupid question
chad_voelkel is offline
Old 12-17-2010, 08:12 PM
  #35
chad_voelkel
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
New to turbines getting a Wren 54
Old 12-17-2010, 09:25 PM
  #36
highhorse
highhorse's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Chad, just go with the ratio Wren says rather than what other guys are doing in other brands.
highhorse is offline
Old 12-18-2010, 05:33 AM
  #37
joeflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wren recommends 3% oil. I mix 3.5 to 4% in mine just to be a bit on the safe side.
Joe
joeflyer is offline
Old 12-18-2010, 06:24 AM
  #38
hooker53
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I mix one Qt. to five Gals of Jet-A in whatever I'm gonna run it in!!! In the Summer I Alt. between 5 Gals of Jet-A and K1 Kero. In the winter month's I burn Jet-A all the way. for the past two years I have use mostly Mobile DTE Lite 24 for turbine oil.
hooker53 is offline
Old 12-19-2010, 12:56 AM
  #39
chad_voelkel
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for all the responses. Im going to pick up my jet today!
Old 12-19-2010, 01:29 AM
  #40
Boomerang1
Boomerang1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I run Wrens (SS & MW44's) at the recommended 3%, no problems at all.
Using the DTE light. - John.
Boomerang1 is offline
Old 12-22-2010, 07:17 AM
  #41
gooseF22
gooseF22's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The wren 54 family can run at 3%-5%. Its in the manual.. RB runs DTE light at the shop if that helps. A few guys run DTE medium at 5%, since its easier to get in gallon jugs.
there are alot of excellent oils, just do a test by mixing some in a small jar and let it sit... if it separates, do not use it..
I run AMSoil synthetic two stroke and dTE light. I ran AMsoil this past season as a test. I ran SAber.. it worked fine at 3%. 5% its a little thick but still worked ok.. 4% was the optimum for all my turbines. THis season, I will probably running the AMSoil Dominator racing oil. Im making sure these oils are good for bearing wear. so far so good. Saber has a very high flash point, so it leaves a little oily residue. again, not bad for bearings though, but i was trying to find the balance. I was the only one running it in my bunch, so we could compare. No fuel/oil related issues seen..w the AMSoil though..
I had to get away from the real turbine oils because they were eating at my hands/skin..
gooseF22 is offline
Old 12-22-2010, 07:30 AM
  #42
siclick33
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The 2 oils mentioned here (DTE 24 and DTE light) aren't the same. They are listed separately on the Mobil website. What the difference is I don't know but it isn't just that they are in different cans.
For what it's worth, I have been using the stuff in asimace's post and it seems ok. I haven't run that many hours on it though.
siclick33 is offline
Old 12-22-2010, 08:27 AM
  #43
gooseF22
gooseF22's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Im looking for a DTE light source in my area. Grainger is 110$ per 5 gal... I know it can be had cheaper somewhere..
gooseF22 is offline
Old 02-06-2011, 09:42 AM
  #44
rcjetsaok
rcjetsaok's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
DTE, DTE Lite, Mobil Jet II , Aeroshell 500...... Will it all work in all engines...??? What is the difference in the DTE and DTE Lite, and which one should we use.??? I am flying AMT and was wondering about switching from Aeroshell 500... Does anyone have a list of Engine Mfg's and what oil is approved for each ???... Dazed and Confused.... AGAIN !!!!
Danno
Old 02-06-2011, 11:01 AM
  #45
yeahbaby
yeahbaby's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
if it has the Milspec 23699?? 2399 ....whatever.....then it should be fine amigo. keep the mix ratio the same but as always the AMT boys should be able to answer, give 'em a jingle.
Quote:
ORIGINAL: rcjetsaok
Danno
yeahbaby is offline
Old 09-06-2012, 08:37 AM
  #46
geonato
geonato's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello anyone can tell me if mobil oil dte light is hydraulic?
geonato is offline
Old 10-04-2012, 04:06 AM
  #47
mjunior
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: geonato
yes.
mjunior is offline
Old 10-04-2012, 05:58 AM
  #48
FalconWings
FalconWings's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ive been using Mercury Premium Oil TCW-3 at 3%, same stuff they use up north.
All good so far, very clean burning.
If someone tells me not to use on their product, I'll simply switch engine brands. That easy.
http://www.mertenmarine.com/servlet/...um-plus/Detail
FalconWings is offline
Old 10-04-2012, 08:00 AM
  #49
ron Sweeney
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am long retired but remember using Mobil dte light in both Hydraulic and mechanical variable speed gearboxes over 40 years ago so it is not a new oil unless, as is likely, some development has taken place.
I know from my petrol engines how difficult it is to remove exhaust oil residue from my models where I use tt two stroke oil so I have always stuck to turbine oil in my turbines. If there are any bragging rights my Wren ss has completed over 61 hours (4% oil) and Wren just tell me to keep running it. I guess there are lots of turbines with more hours but I have certainly had good value, Ron.
ron Sweeney is offline
Old 10-04-2012, 08:54 AM
  #50
highhorse
highhorse's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Pegasus
Pegasus,
My answer would be NO, that's NOT the right stuff. Todd at Dreamworks is selling 32 wt, not 24. Perhaps are others using 24(?) but the stuff is already pretty thin at 32, Todd is no dummy, and I wouldn't use a lighter wt.
My two cents,
Don
EDIT: I just realized the thread is pretty old, as is the Q I responded to. Oh well, perhaps the answer still applies to someone out there so I will let it stand.
Reply
Display Modes
