Mirage 2000
FL
Right on!
Dave, you do great work! I'm still livin! LOL been fiddlin here and there, been scuba diving, and canoeing, etc..... put in some work apps too so mabey my free time is drawin to an end that should get my butt in the jet game again as Murphy's Law says when you dont have time you will want it!
been spot fillin the wings on the F-86 and just lots of finishing work! you know how that goes!
hope all is well on your side of the county-
L.R.
L.R.
Mirage 2000
Dave, you are marching on like an amtrak non stop express ! when you said that you would have it done by september, I laughed to myself , but it looks like I'll have to eat my hat ! good work looks , neat and tidy in the pics too. the mirage is such a good flyer , you will be impressed, ask Rei Gonzalez , he loved his a couple of years ago.... hope top see you fly it soon best wishes .... Malcolm
My Feedback: (61)
AD Mirage
David,
I have built and flown several of these jets. In the 100`s on flights. It will take some time getting used to the profile and the landings but would say that flying this jet made me a better pilot. It is very demanding to see the profile and manage the power settings for landing. You can never be too hot with this jet on landings, bleeding speed is easy. Getting to slow will bite you every time. I lost my first mirage due to elevon flutter. I built a second one and made a mod which ended up being solid at ANY speed.
See pic of my first Mirage. I left the tips attached. The inboard section that has no hinge fluttered.
Vin...
Vin...
#32
My Feedback: (31)
Mirage 2000
Vincent, I like the way you set the elevons up looks great. I almost did something similar to it but I decided to keep mine as close to scale as I can. I am going back to the wood horns and carbon fiber plate them. I also split my elevons up. I am also going to pick up a twin match box for the elevons so I can get perfect alignment. It was difficult to use a standard size servo in the wing tip section but I managed to do it with a frame up. Have you completed yours or are you still building it, You for sure do good work.
Malcom, See I told you I should have it done by September. Just hope I have the paint done too, I can see it taking me many hours for the scheme I am going to go with. I just got an Italery 1/72 scale model and I am going to blow the decals up to 1/6 scale, the decals look similar to the ones in your picture. BTW that Mirage is beauty that you posted.
#33
My Feedback: (61)
Mirage 2000
David,
Those pics are a couple of years old. I sold off my Mirage earlier this year. I am stuck on F-16`s now!! Your split elevon is a good idea, i moved the control servo (8411s`) out in the middle of the wing like you did. The inner servo is in the spot per the plans. When Eric designed this kit he was using jpx engines and the elevon setup was fine. When the higher thrust motors came along there was flutter issues with that setup.BTW i always flew mine with the centerline tank and wing pylons installed, just put the rockets on for static.
Vin...
Vin...
#34
Scratch built M2000
Hello,
I've always wondered where the CoG was located on this Mirage2000. Could u please give me a clue ? For example in a percentage of the maximum chord ...
Another question could u post a pix to give me an overview of the used wing profile ?
I may be willing to scratch build one, one day ...
Thanks.
Thanks.
#43
Banned
My Feedback: (67)
Mirage 2000 by Aviation Design AWESOME Flyer
This Precious Bird is equiped with:
P-120
BVM Super Bandit Gear and Brakes
Airtronics Non Digital Servos
TAM's Pipe
TAM's Tailcone
Built by a very miticulos super scale builder ( Fussinato )
Oh forgot one more thing she flies like a sweetheart
Hope you guys enjoyed the pics......... Johnny Hernandez
P-120
TAM's Pipe
TAM's Tailcone
#45
My Feedback: (31)
Mirage 2000
well I finally found a solution to a fuel cell after debating the idea of a two liter coke bottle. I found a welchers 96 oz bottle at Publix and this is going to be my fuel cell of choice. I will have 100 oz of fuel which will give me adequate flight time. Just need to make some formers and modify the inlets to accommodate the tank. I also drew up a former for my Tam’s pipe and finished the pipe installation, not much left to do before Its ready for the maiden flight.
