If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 31 of 32 FirstFirst ... 2129303132 LastLast
Results 751 to 775 of 777
  1. #751
    Join Date
    Aug 2004
    Prattville, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Habu 32 is here. Jetcat P-20 conversion.
    Gary,
    I have two 910 mah lipos for RX and one 2100 mah lipo for the turbine, smart fly regulator, tamjets conversion kit, Hitec 5085MG thru out and mine came out a little shy of 7lbs dry and 8 lbs wet. It flys wonderfully.
    Dean
  2. #752
    Join Date
    Jun 2002
    Watford, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Gary Jefferson
    Thanks for the information guys. Just one question; it sounds like you are just sliding the batteries through the former but how are you securing them since there is no access to the nose?
    Gary
    The one I did I taped the Li-Po between two 10mm hard wood sticks, cleaned down the ends which were left open like a fork. When you slide the assy in the two sticks squeezed in slightly in the nose keeping the front end held and I had a pad of velcro on the back to stop it sliding out. I'll see if I can find pictures, it was 18 months ago now
    Dave
    Motors & Rotors. JetCat, Powerbox, Intairco, Behotec, CARF-models Rep. JR Propo for ever!, Jet 1A, MAP, Airtech Germany, Jet Tronics.
  3. #753
    marc s's Avatar
    Join Date
    Jan 2007
    farnborough, , UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Same on the original I did for Ali, opened up the former above the tray in the nose section so I could slide the ECU main battery which was taped to a wide lolly pop type stick (think they are called tongue depressors - medical supplies) and slid into the nose section with a small pad of foam on the front to help a snug fit.
    Attached is a picture of the first conversion I did which at the front of the canopy opening you can see a stick with black heatshrink over it secured with a screw to a carbon looking support plate near the opening this has a battery attached to it which was slid into the nose. Hope that helps.
    marcs
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  4. #754
    Join Date
    Jun 2009
    Kuala Lumpur , MALAYSIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Marc, Do you still have the conversion kit available that Ali was selling? I've just bought the model and assumed i would still be able to buy this kit to fit the P-20. Thanks. Tom.
  5. #755
    marc s's Avatar
    Join Date
    Jan 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sorry no, I stopped making them a while back as I needed my life back
    marcs
  6. #756
    Ali's Avatar
    Join Date
    Apr 2002
    Northamptonshire , UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey Tom! Good to hear from you again.
    Unfortunately as Marc said the wonderful Habu conversions that he made for us are no more.... Good news is that I saved just one of the Pro conversions. I thought I may want to revisit the turbine Habu one day... It's yours if you want it !
    Regards Al
    Al's Hobbies, Horizon Hobby, Airworld, BVM, Jet Cat, Skymaster, Rc Jet Centre,pull over, Tomahawk, C-ARF, Jet-Teng,Kingtech
  7. #757
    Join Date
    Jun 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Ali, Great to hear from you as well. That sounds absolutely perfect. How do i get it from you? I see your profile going up and up. Hope your Dad and the shop is doing well. Let me know how to get the kit from you and let's do it. You have a P-20 as well? Thanks and take care. Tom.
  8. #758
    Join Date
    Jun 2006
    Ona, WV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Have been flying a stock Habu32 stock fan and 6s pack with TJ struts out of our grass field, I am building another P20 version shortly with TJ struts as well. Does the P20 have have same thrust at takeoff as stock eflite fan or less? Want to make sure takeoff won't be a problem, our field is fairly long at 630' +
  9. #759
    Join Date
    Feb 2012
    angervilliers, FRANCE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello
    Sorry for my bad english, but i'm french :-)
    I want to convert a Habu but where i can buy a conversion kit.
    From what i've read in this topic, gbr jet no longer produces conversion kit.
    Thanks for you answer
  10. #760
    Join Date
    Sep 2002
    Copenhagen, DENMARK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sonnich Johannesen
  11. #761
    Join Date
    Sep 2006
    Sydney, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Maidened my Habu32 P20 last weekend. 6.7lbs dry. No weight needed to balance.
    Like others that have flown one, a very impressive performer that flies bigger than it is.
    I cut the nose off the fuse and mounted batteries, hopper tank and turbine ancillary gear in the nose space. An easy mod to do and worth it for the space gained.
ID:	1880201   Click image for larger version.
ID:	1880202   Click image for larger version.
ID:	1880203   Click image for larger version.
    Jet Products Australia
    www.jetproductsaustralia.com
  12. #762
    Henke Torphammar's Avatar
    Join Date
    Oct 2002
    Ljungby, SWEDEN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: philjac94
    I know exactly what you mean, all smaller planes get a locked in feeling much like the larger ones when powerd by a turbine. Everything from a funjet to the larger 120mm ones. Even though you might not think it's the case, it's very diffrent from flying it with electric power.
    /Henke
    www.youtube.com/henke2
    Ready2fly - T45 Goshawk, Lambert Kolibri T35. Perfect if I want to do carrier training!
  13. #763
    Bob_B's Avatar
    Join Date
    Nov 2003
    Bluegrass State of Mind
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Unless your using. A real man edf unit
    2017 Fall Jet Classic - Event Dates October 4-7, 2017
  14. #764
    Join Date
    Jan 2002
    Lebanon OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I started flying my Habu from a grass field last weekend and I am amazed at how well the plane flies. I was landing in 10-12mph crosswinds and it really handled the landings. I am in the process of installing some gyros on the flying surfaces so that I can fly it regularly in higher winds at jet meets.
    Like everyone else has mentioned it flies like a much bigger plane and has a very good top end speed with the P-20. It can get pretty far out pretty quick but I do think it is has nice visibility in the air.
    The best thing about the plane is no assembly/dis-assembly is required to carry it back and forth to the field. And, I can probably get 4-5 flights on one gallon of fuel.
    Gary Jefferson
  15. #765
    ORIGINAL: Bob_B
    LOL...
    How about short man power with a lot of green bottle a night before
    [youtube]http://www.youtube.com/watch?v=3P0Q-mpRy7M[/youtube]
    Tam Nguyen
    Owner TamJets
    www.tamjets.com
  16. #766
    Bob_B's Avatar
    Join Date
    Nov 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Of course Tam many green bottles
  17. #767
    Join Date
    Jun 2006
    Ona, WV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have a question on where most have placed the fuel shut off valve. I have mine between the tank and pump using the jetcat/tetra ball valve because it was easy to come off the header using 4mm to the valve then reduce it down to 3mm before the pump. I have flown this way and no issues, but concerned it really should be on the pressure side, because I tested a tetra style valve on a butane line and it leaks gas when shutoff around the seals so I fear it could potentially suck air. If I move to the pressure side then I will have to use 2 reducers to go from 4mm to 3mm. Just polling to see what others have done for this arrangement.
    Thx
  18. #768
    BaldEagel's Avatar
    Join Date
    Oct 2005
    Kent, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Use 4mm to the pump and 3mm out of the pump with the valve between the pump and the turbine, to put 4mm onto the pump use a short piece of 3mm on the pump nipple and push the 4mm over it and wire tie, pump gets better feed and the ECU will regulate the flow to the turbine, the shut off valve should be after the pump to allow shut off in the case of a pump runaway.
    Mike
    My Gast is Flabered.
    No matter what anyone say's 100% is the maximum you can get.
    If you see a deleted post, my Avatar say's it all.
  19. #769
    Join Date
    Jun 2006
    Ona, WV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for that, wish they made a ball valve with 3mm nipples so I don't have to step it down before and after.
  20. #770
    mick15's Avatar
    Join Date
    Apr 2002
    Essex, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The manual valve must be on the induction side of the pump!! People grossly underestimate the pressure a Hausl pump can deliver, these pumps will deliver 280lbs of pressure enough to blow up neoprene tubing with predictable consequences.
    m
  21. #771
    Join Date
    Feb 2012
    Dublin, IRELAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Quote Originally Posted by raptor30se View Post
    I'm in the same boat with my P20 Habu 32. I run a ball valve after the header / before the pump.
    On a second note, have you seen that Jets Munts are working on a 35nm turbine? I saw it at Jetpower, it seemed to be similar size and weight to the P20 so I'm thinking it could be a nice upgrade
  22. #772
    mick15's Avatar
    Join Date
    Apr 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm waiting for that as well, it's a collaberation with John Wright's little "Sprite" I have used one, a very impressive little engine indeed.
    m
    http://youtu.be/_oeiK5FX5ks
  23. #773
    v8mini's Avatar
    Join Date
    Dec 2005
    Banbury, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Quote Originally Posted by mick15 View Post
    m
    I've also been lead to belive that valve should be before the pump, if the fuel line fails the pump will keep pumping fuel into your airframe unless you can shut off its supply easily
  24. #774
    hi guys,
    i registered to this forum to contact Marc from GBR Jets to ask him for a kit of conversation for my habu 32 and luckily he got one for me (and seems to be the last one).
    Today i maidened my habu with the p20 sx and it was a very great fly with a wonderful sound.
    I would like to congratule with Marc and Ali for this wonderful conversation and also thanks all the guys who share their ideas and experience in this project.
    I attach some photos of my Habu
  25. #775
    hi guys,
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
