Now That will add some confusion
Banned
1 Post
We already have Ducted Fan (DF) Electric Ducted Fan (EDF), and Turbine (Turbine) powered jets. Now young Tommy over at Airpower is calling his EDF stuff EPF Turbines
http://www.airpowerrcpro.com
That will confuse some of the new commers
Dennis
Dennis
CA
RE: Now That will add some confusion
Dont forget NDF (Nitro Ducted Fan) or GDF (Glow Ducted Fan).
The definition of Turbine from Wikipedia says: A turbine is a rotary engine.......
Last time I checked a electric motor was a motor and not a engine!
ORIGINAL: 1320Fastback
ORIGINAL: Square Nozzle
Man, I really have to jump on this one. 1320 Fastback has it right but incomplete. It really bothers me when engines get called motors. An engine is an engine not a motor.
While most people and gear heads consider an engine as a device that burns fuel to create motion, and a motor as a device that uses any other form of energy to create motion.
Per Miriam-Webster;
Definition of ENGINE
4: A machine for converting any of various forms of energy into mechanical force and motion; also : a mechanism or object that serves as an energy source <black holes may be the engines for quasars>
Definition of MOTOR
1: one that imparts motion; specifically : prime mover
2: any of various power units that develop energy or impart motion: as a : a small compact engine b : internal combustion engine; especially : a gasoline engine c : a rotating machine that transforms electrical energy into mechanical energy
So technically Motor and Engine are interchangeable.
Hey, don't shoot the messenger, I'm not the one that wrote the dictionary.
My Feedback: (8)
No offense Jeff. The guy that wrote the dictionary was likely an English major and wouldn't know an engine if it hit him in the head.
Mazda Continental Motors
Detroit Motor Show
General Motors
Motorcycle
Etc.
Etc.
Etc.
If one says either "motor" or "engine" and you know he means, the message has been successfully conveyed...therefore correct.
Personally, I use "engine" when referring to fuel fed motors and "motor" when referring to electric engines.
If 50 people jump off a cliff in front of you do you follow? I put fuel in my engines and plug my motors into the wall. Today if someone talks about the "motor" in his plane I don't know if he's flying with an electric motor or an engine. Nuff said.
AZ
_____________________________
John
John; So you can't even explain why is call ..Motor Oil, Or even "Motorsports"?
Or even ,Indianapolis "Motor" Speddway ,at least BMW?
Nuff Said!!..
Or Explain!
A..
John
Nuff Said!!..
Or Explain!
A..
ORIGINAL: AWAR
John; So you can't even explain why is call ..Motor Oil, Or even ''Motorsports''?
Or even ,Indianapolis ''Motor'' Speddway ,at least BMW?
Nuff Said!!..
Or Explain!
A..
Nuff Said!!..
Or Explain!
A..
Sooooo, take a stand and write to Congress about your concerns.
My Feedback: (8)
ORIGINAL: FILE IFR
Unlike you, most couldn't care less about it.
ORIGINAL: AWAR
Nuff Said!!..
Or Explain!
A..
Nuff Said!!..
Or Explain!
A..
Banned
1 Post
ORIGINAL: 3dean
bigplumbs, top marks !!!!
I have just been sitting here and watching things go off topic
Dennis
Looks like the fan is made by EPF Hobby co ltd. air power are a just distributor LOL
http://www.epf.com.tw/index.html
The explanation that I heard is that an engine is a device that does work by the indirect conmversion of energy, whilst a motor is a device that does work by the direct conversion of energy.
So a heat engine, eg: steam engine, IC engine, jet engine produce heat first from the fuel, and the heat does the work.
A rubber motor and and electric motor directly convert enegy into work. Don't know if it's right but there does seem to be some rationale to it.
ORIGINAL: rjbob
Now that's what I call puttin' fuel in his motor!
Bob,
Yup. He hasn't posted in 2 years and decides to log on to challenge one of the good guys .... A true winner.
AZ
Score: 105
Last Login: 1/11/2011
Status: offline
quote:
ORIGINAL: rjbob
Bob,
True Whinner??....Let me Guess ,FILE IFR , Just bla, bla ! and obviously ....... You Can't explain why is call "Motor Oil" or..can you ???[:-]
Read more: http://www.rcuniverse.com/forum/m_10...#ixzz1AgyK17pB
ORIGINAL: AWAR
True Whinner??....Let me Guess ,FILE IFR , Just bla, bla ! and obviously ....... You Can't explain why is call ''Motor Oil'' or..can you ???[:-]
