EMCOTEC UniveralTester
Hi everybody,
does anyone know the EMCOTEC UniveralTester?
I bought it and can not connect it correctly, I found instructions poorly made, because it shows no time, a small drawing or a picture, that show how to connect it ... so, is anyone of you use it and could do me a photo of his connection?
thank you in advance. :-)
PS: knowing, of course, that it has been many months since I try to get this from a EMCOTEC ... they are pathetic ...
Eric B @ + +
http://shop.rc-electronic.com/e-vend...&t=6&c=67&p=67
Eric B @ + +
RE: EMCOTEC UniveralTester
hello
I possess of course, this manual, but I find it very poorly explained and there is no drawing of the connection ...
regards
eric
regards
eric
Looks like there is only one connection to be made, (Apart from the optional alarm-led)
Plug it in to a RX channel and go. What exactly is the problem you're having?
Hans
Hans
Good evening,
sorry but it would be too easy ...
this system does not work in 4.8 or 5V.
Here is the answer to EMCOTEC:
Dear Sir
you have to set to Lipo (programm 2).
You must connect the tester directly to the Batterie not to the receiver, because it is regulated.
Mit freundlichen Grüßen
Ihr EMCOTEC Support-Team
Dipl. Ing. Andreas Peukert
after that, I asked him how make the connection because I do not see, except maybe directly? but I've never had a reply ...
regards
eric
Dear Sir
regards
eric
Is this your setup?
2s Lipo through regulator to receiver.
You want to monitor battery voltage?
I don't own one of these but I think it is straightforward.
You need to attach it to the wire between the battery and the regulator.
What type of plug is there on the battery? If it is a JR connector you could use a Y-lead. I would want to make it more permanent so would either solder it to the regulator plug (the one that plugs into the battery) or, if you don't want to cut the plug off the Tester, you could cut the plug off a servo extension and solder that to the regulator connector and then plug in the tester.
Or use a regulator that monitors battery voltage such as EMCOTEC BIC or powerbox.
++ Hi
Is this your setup?
++Yes
++Yes
++ yes, that's what I thought too ...
++Exactly
++I would like simply to turn it on at the same time I turn on the switch.
I do not want it to remain turned on all the time, and I want it gives me the voltage of the lipo.
++ Regards
Eric
Is this your setup?
++Yes
++Yes
++Exactly
++ Regards
Eric
Did you sort this out?
What type of regulator are you using? If you have a separate switch and regulator it is easy.
Wire the components in the following order: Battery, switch, regulator, receiver. You need to fit the tester between the switch and the regulator either by soldering the wires or making up a plug.
If you have a regulator with its own internal switch then I don't think it can be done (without adding a second switch would be a pain).
ORIGINAL: siclick33
no, not yet, but you gave me a good track to follow. :-)
i will try maybe tomorow and i'll tell you after. :-)
thanks a lot for all.
regards
eric B
