Century Jet A-7 with PICS
My Feedback: (28)
OH
RE: Century Jet A-7 with PICS
from centuryjets.com:
SPECIFICATIONS:
Wing Span: 66.5"
Length: 79.5"
Weight: 24 Lbs.
Channels: 6 to 10
Scale: 1:7
Propulsion: One 17 to 27 pound turbine
SPECIFICATIONS:
Wing Span: 66.5"
Length: 79.5"
Weight: 24 Lbs.
Channels: 6 to 10
Scale: 1:7
My Feedback: (12)
CA
I will give them a call on Monday and see if I can't get them coming. Frank, thanks for that info, I found it on the site as well, just hoping someone has some insight as to whether the P-70 will do fine or if I should install my 120, my F-86 is 31 pound wet with a P-70 and flies just fine, so kinda thinking this may be the same, also not sure if the 120 will fit in the bypass, I have the entire full ducting and pipe, which is far to heavy.
going to to replumb the gear this weekend and see if I can't get them working, there is a crazy amount of stuff going on with the gear.
I know there is at least one flying and hope he will chime in with some tips as to how she flys.
Kevin
Kevin
My Feedback: (12)
CA
I sent Johntg a PM, no response as of yet. got the gear to retract and deploy as they should. I have to replace all the airlines as the ones in the plane now are a very stretchy rubbery line and can be pulled off the nipple with little force. I have a Tamjets pipe from a FeiBao hawk that is the same length and sutiable for the 120 at a weight savings of 10 oz. hopefully the 120 fits within the bypass as this will make for a very clean install. would like to see some video of one of these flying, hope it flys as good as it looks.
Kevin
Kevin
My Feedback: (12)
CA
removed the tanks tonight and and started to layout component location. called Century yesterday and can get the pylons and adapt them to my wing. this turned out to be a early Century/Kranz kit. got some valuable info to get me started with the install.
Kevin
Kevin
