Santa finally arrived with my beer! ** Started Building **
My Feedback: (28)
OH
RE: Santa finally arrived with my beer! ** Started Building **
Were you get the decal for the nose? I was gonna have one made (without the mountains behind the "coors lite")
My Feedback: (28)
OH
ORIGINAL: RCISFUN
And who were you going to have make it
I think the second photo looks better though
Well it is the first one (second one is a little "TOO BIG" for the nose).. BUT it needs to be out of vinyl. Im not re-clear coating the plane.
#31
I have my own sign company,so I can print just about anything, I usually don't clear coat its pretty durable it haven't had problems yet i have planes 10 years old and the still look good.
Frank
Frank
#32
My Feedback: (28)
OH
ORIGINAL: moki180
Frank
Frank
#33
My Feedback: (28)
OH
Though I show a few more photos of the service panel install:
Under the panel I have the air tanks, smoke pump, and steering servo. Had plenty of room for a nice & neat layout, sprayed the panel white and labeled. Also made a mod to the nose gear doors, since skymaster design wass off I made the bottom half of the door on hinges and cylinder. Used a UP2 valve to keep the bottom door shut all the time. Left the top half of the nose gear door to stay on the linkage to pull it shut.
Top panel is screw down, if (or when) I need to remove it I can take it out.
#35
Built a tank tray and replaced the middle bulkhead to have room for 2 x 20 oz smoke tanks, main tank dubro 100oz is centered on the cg . The tray is end grain balsa sheeted with 64 ply very rigid and lite and will have pins at the rear so it will be removable to access the smoke pumps.
#36
My Feedback: (28)
OH
Great Decal you made for me!!!! I should have got one without the grpahics and paid you for the decals!!!!! That main tank from xtreme is 90oz, I am using that to feed my header trap. Im using 2 12oz sullivans (DF style tanks to be on each side of 90oz tank) + 6oz header for smoke. Plus all 3 tanks are centered on CG. Have to mount the tail pipe before I can install the fuel tanks.
#37
My Feedback: (28)
OH
ORIGINAL: moki180
BTW... I would try to get the smoke tanks on CG.. The way yours is installed, you are gonna be nose heavy and be up trimming till you empty them.
#38
My Feedback: (28)
OH
youtube maiden:
[link=http://www.rcuniverse.com/forum/m_10571536/anchors_10572256/mpage_1/key_/anchor/tm.htm#10572256]BD-5 Maiden Video[/link]
#39
Here is Frank's maiden flight of the BD-5 with a Rabbit Turbine.
[youtube]http://www.youtube.com/watch?v=e2Bvf__znJE&feature=channel_video_title[/youtube]
#40
My Feedback: (44)
Frank does that mean it will be ready for the OC Turbofest?
http://www.rcuniverse.com/forum/m_10572109/tm.htm
#42
My Feedback: (28)
OH
ORIGINAL: Todds Models
Did you guys find 3 hinges per flap good enough or did you add more?
