The reason JetCat's are boring
My Feedback: (51)
RE: The reason JetCat's are boring
ORIGINAL: BaldEagel
Agreed, If you have a P20 and some A123's please try it out and let us know if the pump is still OK.
Mike
ORIGINAL: i3dm
a three cell A123 pack will only stay above 10V for a short period of time, and then go down to constant nominal 9.9V anyways.
Mike
If i had a P-20 i'd be out flying it !
Then I don't understand the information I have been given by two reliable sources that the Pump can not take over 10 volts from the ECU battery? How does 10volts get to the pump to make this information/statement correct?
Mike
Mike
#32
If there are 4 wires going to the P-20 pump instead of just two as on my Wren 44's Flightworks pump , then maybe there's some active circuitry within the pump body that maxes out at 10V.
Gordon
Gordon
#33
Doesn't the P-20 pump have 2 integral solenoid valves in a block ?
4 wires could be
+ve supply
pump pwm -
kero/gas start solenoid pwm-
run solenoid pwm-
4 wires could be
+ve supply
pump pwm -
run solenoid pwm-
#34
If you look at the pic on post 1 you will see the valve block by the side of the pump, these plug into the pump for their power and I presume signal, hence the four way plug into the pump you are probably correct on the signal wires for the valves, but the valves are not integral to the pump.
Mike
Mike
#35
My Feedback: (73)
I know what you mean about boring ! lol I came into the hobby on Jetcat p80 abd p120s ... But some of the most fun i have had with jet engines has been running manual air start on some AMTs i had/have ... Its fun being manually being involved in running up the air, kicking in the gas, backing off the air, lighting the plug, and ramping back up with the air, and being able to have a "feel" for it getting perfect starts [8D] .. then again the thought of lugging around a scuba tank, start valve boxes, etc still made me opt to use my p200 in my latest project over an air start at450 ... fuel and go
~V~
~V~
#36
ORIGINAL: Couch Potato
4 wires could be
+ve supply
pump pwm -
run solenoid pwm-
4 wires could be
+ve supply
pump pwm -
run solenoid pwm-
Gordon (who always finds his Wren 44s exciting )
#37
Copy of a post by Dave Wilshire:
Mike
The ECU V10 could run on 3xA123 batteries (ECU accepts up to 14V) but not the P20-pump. This is limited to maximum 10.0V input.
JeyCat recommend to run the P20 only with 2S LiPo!
On upcoming engines using the ECU V10 it will also support 3cell A123 batteries, but for me on small models the weight of A123 makes little point.
(2xA123 cells will not works as they provide too low output voltage, ECU needs 7V at minimum)
Dave
I have had a similar responce from Ali.
Mike
Mike
Dave
Mike
#38
You guys have put forward some good reasons why the pump will never see the ECU battery voltage, I wonder why two reliable sources have been told not to use three cell A123's and that its the pump that will not take over 10 volts by JetCat? the question has been asked on the JetCat Turbine Clinic thread without any responce so far, It will be interesting to see what transpires.
Mike
Mike
#39
Hi Mike
The comments that I posted were a direct copy and paste from an email that I received from Roman at Jet Cat. Other than Markus ( Owner and designer) I dont think anyone else at JC has as much knowledge of the turbines as he does.
Regards Al.
Regards Al.
#40
Hi Mike
Regards Al.
Regards Al.
#41
Hi Ali
I just repeated what you had told me and I belived to be correct, others have different opinions, hence this disscusion, it would be nice to get an explanation to satisfy everyone, perhaps we will in the JetCat Turbine Clinic thread.
Mike
Mike
#42
Hi Mike,
No problem at all . I just wanted to make sure that everyone knew where the information I was providing came from.
Regards Al
Regards Al
#43
ORIGINAL: BaldEagel
Mike
Mike
Markus designs the electronics on all JetCat's it was him who had given me the information I posted last week for you. The P-20 pump is magnetic drive...
Dave
#45
Banned
1 Post
ORIGINAL: BaldEagel
The delivery of my P20 from Ali was next day within the time hour specified, Put the P20 on a rig, attached the Rx, Learn RC came up on the GSU, did what I was instructed by the GSU, fueled up throttled up and it started, what impressed my the most was the spool up time, from 85,000 to 245,000 took about 3.5secs, not scientific, just a count on my watch.
Mike
Mike
#46
ORIGINAL: bigplumbs
I cant believe it started first time..................... You are using a Futaba
ORIGINAL: BaldEagel
Mike
Mike
Mike
#47
ORIGINAL: BaldEagel
On second thoughts the Pump voltage is possible controled in the same manner as an ESC controls an electric motor in which case it sees the ECU voltage the whole time and is switched on and off to control the speed of the pump, this is suposition on my part and I am only quoting the information I have received. i.e. the pump can not take over 10 volts.
Mike
Mike
The P20 has a requirement for 110cm of fuel line into the turbine from the pump, this is to prevent pulses from the pump reaching the turbine, this is very evident on start up on a Kero burner without the long length of fuel line, but does not seem to inhibit the good starting I have experienced so far, I am running the P20 in a Toki Ducty without a UAT just a pleasted paper clunk filter in the main tank, so far faultless running and so much fun, just grab a fuel bottle and Tx and go fly, no retracts or brakes to pump up, simple winter flying fun.
Mike
