Futura 1.9m Build
Old 11-21-2015, 10:11 AM
  #426
lxfly
lxfly's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fuel tank capacity = 2.8l or 0.74 gal
lxfly is offline
Old 11-21-2015, 10:34 AM
  #427
shepp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
rene is right, tomahawk list it as 2.8 liters All I know is that with a P-80se, I get 8 minute flights with plenty of reserve probably could do 10 minutes depending upon throttle management
shepp
shepp is offline
Old 11-22-2015, 02:30 PM
  #428
RickyBoy48
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
2.8 litres
RickyBoy48 is offline
Old 12-03-2015, 06:44 PM
  #429
rbgetz
rbgetz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a question on the thrust tube installation. Obviously you use the two tabs to connect it by the turbine, but where it exits the aft end of the fuse, do you just let it float or friction fit out the tail? I wasn't sure if only using the two tabs was enough to hold in place.
rbgetz is offline
Old 12-03-2015, 07:09 PM
  #430
RickyBoy48
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mine was a tight fit going through the rear of the Jet had to sand the hole a bit, protrudes thru the rear of the Jet around an inch. Don't worry about heat it stays nice and cool
Old 12-03-2015, 08:01 PM
  #431
rbgetz
rbgetz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Rick... it's definitely a nice double walled thrust tube, and I wanted the ability to remove if necessary. Nice to know the heat isn't going to be a factor. I'll do the same and sand enough for a tight flt.
rbgetz is offline
Old 12-11-2015, 05:53 PM
  #432
rbgetz
rbgetz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, I finally got the Futura sitting on its gear for the first time tonight. moving along a little slow. All control surfaces installed and setup as well. got the tanks installed with a simple light weight design. Also shaping a cardboard template for the equipment deck. I ended up using the BVM canopy hooks. also used grey foam board for cockpit base. Just got word my K-120 is finally on the way from Taiwan. Thought I just share some of the progress
ID:	2135443   Click image for larger version
ID:	2135444   Click image for larger version
ID:	2135445   Click image for larger version
ID:	2135446   Click image for larger version
ID:	2135447   Click image for larger version
ID:	2135448   Click image for larger version
ID:	2135449   Click image for larger version
rbgetz is offline
Old 12-11-2015, 07:39 PM
  #433
RickyBoy48
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Excellent, very nice
Old 12-14-2015, 07:46 PM
  #434
rbgetz
rbgetz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was curious on how people attached the tail cone. I wanted to use some 3/8" (9.5mm) button head canopy screws, but they're too long and would go through the exterior wall of the thrust tube. seems like only around 1/8" before hitting that outer wall. very tight space, or does it matter to screw into the outer wall of the thrust tube?? Rob
rbgetz is offline
Old 12-15-2015, 02:11 AM
  #435
lxfly
lxfly's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, doesn't matter. You may drill holes of exterior wall a bit greater(or make it oval) and the outer wall is drilled to hold the screw. The points of the screw entering the tube may be cut later on.
lxfly is offline
Old 01-02-2016, 05:16 PM
  #436
rbgetz
rbgetz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
With the holiday I had a lot of extra time to work on the Futura and was able to finish it.. Did the first start with the K-120G mounted in the air frame yesterday and final weight and balance check... Now if only the snow will clear off the runway!
ID:	2139346   Click image for larger version
ID:	2139347   Click image for larger version
rbgetz is offline
Old 01-02-2016, 05:34 PM
  #437
RickyBoy48
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Excellent she is beautiful....very ell done
Old 01-02-2016, 07:47 PM
  #438
rbgetz
rbgetz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rick, I really appreciate your help. I read your build on RCCanada and got some additional tips. I'm new to jets and just trying to take it all in.
rbgetz is offline
Old 01-18-2016, 10:21 PM
  #439
BoomerSooner
My Feedback: (80)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
how did you guys secure the rudder hinge pin? I really dont want to bend the top and tape it to the top of the stab. I'm in the home stretch on mine and haven't figured out how I want to secure the rudder pin.
BoomerSooner is offline
Old 01-20-2016, 07:25 PM
  #440
rbgetz
rbgetz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi BoomerSooner.. Good question. Mine seems to fit tight enough to leave as is. I'm really new to the Futura and haven't even maiden-ed it yet. so I'll let the experts chime in... but if it's fairly tight, I don't see an issue, just something to check. Is yours really loose?
rbgetz is offline
Old 01-20-2016, 08:41 PM
  #441
BoomerSooner
My Feedback: (80)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nope not too loose but just feel better about securing it. I worked it out today. Took a set screw and put the hinge pin into the Allen hole in the set screw then soldered them together. Then I took a Dremel thin cut off wheel and ground a slot in the head of the set screw to be able to use a small flat head on it. Opened up the hole in the top of the stab a bit and screwed it in. Good to go now. Hopefully have mine finished up in a couple days. Just need to finish up the equipment tray
ID:	2142598   Click image for larger version
ID:	2142599   Click image for larger version
ID:	2142600   Click image for larger version
ID:	2142601   Click image for larger version
ID:	2142604   Click image for larger version
ID:	2142605   Click image for larger version
Old 05-10-2017, 02:48 AM
  #442
kirill1958
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello to all Futura 1.9 owners!
I have a tricky question - can you please measure the width of the fuse in the widest point (intakes), the reason for asking is - I'm trying to figure out if the plane will fit my car's roofrack so I can have a bigger jet inside and smaller one in the rack. I know that UltraFlash for example fits with no issues (tried to put my friend's UF there - no problems), but Futura seems much wider and thus I doubt that the rack will actually close.
kirill1958 is offline
Old 05-10-2017, 05:10 AM
  #443
rbgetz
rbgetz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's about 14.5" at the base of the fuse at the intakes.
rbgetz is offline
Old 05-10-2017, 05:12 AM
  #444
rbgetz
rbgetz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
....or just under 37 centimeters
rbgetz is offline
Old 05-10-2017, 05:18 AM
  #445
kirill1958
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank's!!! I'll go see if it fits!
Old 06-13-2017, 05:37 AM
  #446
Jonas Bergström
Jonas Bergström's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi all
I have just bought a used Futura 1.9m, and I missing the manual. I have asked for a copy from Tomahawk Design but without any answear.
Is there any one ho has one and can mail it to me.
jonas.bergstron(a)arcam.com
Jonas Bergström is offline
Old 06-14-2017, 01:06 AM
  #447
lxfly
lxfly's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok, sent you a link to your mailbox: resent it as your email is incorrect.
lxfly is offline
Old 12-08-2019, 07:55 AM
  #448
LewisE1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just about to start building one of these, just deciding on a turbine, either a 100xbl or kingtech 120g2, I have used jetsmunt a few times and like there engines but I am tempted by the 120, any one using either of these ?
LewisE1 is offline
Old 12-08-2019, 08:19 AM
  #449
RickyBoy48
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi, I used a Jet Central Cheetah 160 in mine. I sold my first one and then my wife bought me a new one. The Black, White and Green one.
Rick
Old 12-08-2019, 08:33 AM
  #450
LewisE1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That’s a lot of power for a 10kg model !
LewisE1 is offline
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
