E Flight HABU 32- P-20SE Build thread+Videos*
Reply
Old 02-23-2011, 12:41 PM
  #51
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: E Flight HABU 32- P-20SE Build thread+Videos*
Tail tip skid included with our package
Rudder cable route.
Another nose Oleo option, but not with the supplied wheel! Ideal main Oleo on other small P-20 jets!!
Dw
ID:	1568782   Click image for larger version
ID:	1568783   Click image for larger version
ID:	1568784   Click image for larger version
Dave Wilshere is online now
Old 02-24-2011, 02:42 PM
  #52
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rudder servo cable taped over and light ply cover, glued onto the servo mount to protect the servo from heat soak.
As std the kit comes with paired elevator servos, so that a single channel can be used with a Y lead, I want to use 2 channels and although that's easy with this set-up the LH arm heading for the duct/turbine is not ideal. Easy mod', trim the support block and take 2mm from it and the tube will align with the opposite side.
Decided to tint te canopy glass too before installing the tub and a pilot.
Dw
ID:	1569336   Click image for larger version
ID:	1569337   Click image for larger version
ID:	1569338   Click image for larger version
ID:	1569339   Click image for larger version
Old 02-24-2011, 02:44 PM
  #53
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dw
ID:	1569345   Click image for larger version
ID:	1569346   Click image for larger version
ID:	1569347   Click image for larger version
ID:	1569348   Click image for larger version
Old 02-25-2011, 02:18 PM
  #54
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mrs W out with the girls has given me some workshop time, so tail pipe in. Rails give turbine correct spacing and support the tailpipe. Augmenter? will help suck the heat from the fuselage. 4 pcs 6mm sq hard wood space the pipe centrally.
Dw
ID:	1569775   Click image for larger version
ID:	1569776   Click image for larger version
ID:	1569777   Click image for larger version
Old 02-25-2011, 03:06 PM
  #55
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Turbine fixed and dead centre without any adjustments[8D]
ID:	1569791   Click image for larger version
Old 02-25-2011, 03:16 PM
  #56
simont
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Dave Wilshere
Dw
You sure do love your blue canopy tint. This one, and at least 2 Nano's so far. [&:]
simont is offline
Old 02-25-2011, 03:51 PM
  #57
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Decided that my first choice smoke would be too dark with this scheme, I have plenty of models with the Blue tint something bright to pick out on a dark scheme.
Dw
Old 02-25-2011, 04:20 PM
  #58
ianober
ianober's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What is the solution for brakes? So far this setup would be out of regulation with the AMA.
ianober is offline
Old 02-25-2011, 04:45 PM
  #59
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There is a choice of wheel brakes out there...whether they are any use on a 7lb model and 2 square cm of contact? I've not read the ruling recently to know the exact requirements from the AMA rule.
Old 02-26-2011, 08:32 AM
  #60
bigplumbs
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I suspect the rule was made well before small turbines like this were envisaged.............. Change the rule I say
Dennis
bigplumbs is offline
Old 02-26-2011, 10:14 AM
  #61
bukeym
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can you send some links for these brakes? Where can I purchase them?
THanks
bukeym is offline
Old 02-26-2011, 10:16 AM
  #62
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wiring just about completed, I used two stock Y leads to make the U/C harness. Nose unit in with stock wire leg for now (need to machine a wheel for the oleo I want to use)
ID:	1570211   Click image for larger version
ID:	1570212   Click image for larger version
Old 02-26-2011, 10:23 AM
  #63
Alex48
Alex48's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
TamJets are making some oleo's and brake combos specifically for the Habu 32, try emailing him for prices.
Alex48 is offline
Old 02-26-2011, 10:28 AM
  #64
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.cmldistribution.co.uk/cml...tId=0000005454
Old 02-26-2011, 02:17 PM
  #65
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Long day installing and I'm just about there, few stickers and a systems check should allow a motor test run tomorrow.
Dw
Looks like I found the reason Mrs W cakes vary 6.5lb actal weight on postal scales
ID:	1570325   Click image for larger version
ID:	1570326   Click image for larger version
ID:	1570327   Click image for larger version
ID:	1570328   Click image for larger version
ID:	1570329   Click image for larger version
Old 02-26-2011, 02:31 PM
  #66
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jumping back, the extra tube is coiled just behind the canopy.
ID:	1570338   Click image for larger version
Old 02-26-2011, 03:02 PM
  #67
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Radio set-up complete and gear checks out
ID:	1570349   Click image for larger version
ID:	1570350   Click image for larger version
ID:	1570351   Click image for larger version
ID:	1570352   Click image for larger version
ID:	1570353   Click image for larger version
Old 02-27-2011, 06:47 AM
  #68
hooker53
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave, What was the final tank/fuel capacity?? Nice job on this one!!!
hooker53 is offline
Old 02-27-2011, 07:05 AM
  #69
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Three flights today before rain stopped play, brilliant model. Final weight ended up just over 6.5lb with some nose weight added. The main U/C could go back a bit which would make ground handling even better, those fitting TL oleo's will get that. For me I'm happy with the wire legs that even on our long wet grass did not bend. I'll fit a nose oleo to improve the look. Very little trimming required, though flap/elevator was needed with the small 3/16" 5mm Crow i'm running, 10% on TO and 25% on landing, I'll measure amounts soon. I also need to check actual balance point as flown, which seems good and in KE tracked well.
Slow flight is great, very powerful flaps allow super power slow landings.
Trevor managed to get a little video of the test flight and will post sometime.
Dw
ID:	1570691   Click image for larger version
ID:	1570692   Click image for larger version
ID:	1570693   Click image for larger version
ID:	1570694   Click image for larger version
ID:	1570695   Click image for larger version
ID:	1570696   Click image for larger version
ID:	1570697   Click image for larger version
Old 02-27-2011, 07:07 AM
  #70
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: hooker53
22oz and I'm flying 6 1/2 minutes mixed throttle.
Nice aeroplane, has lots of potential...
Dave
Old 02-27-2011, 08:10 AM
  #71
POWER JET
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
which servos you are using in the surfaces?...elevator aileron and flaps?
POWER JET is offline
Old 02-27-2011, 08:22 AM
  #72
tamjets
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good Job Dave.
Now my turn go maiden the T-45.
tamjets is offline
Old 02-27-2011, 09:37 AM
  #73
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: POWER JET
JR 331 on all main controls except Rudder which has a JR 362. Nose steering is a MG New Power, as I needed opposite rotation for Y lead rudder/steering. Controls are Thr, Ail 1,Elev 1, Rudder/steering, Gear, Flap 1, Ail 2, Elevator 2, flap 2.
Tam-get on it then!
Dave
Old 02-27-2011, 09:43 AM
  #74
GrayUK
GrayUK's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice job Dave.
Paul
GrayUK is offline
Old 02-27-2011, 09:48 AM
  #75
marc s
marc s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes they fly really well, and yes they need nose weight
marcs
marc s is offline
Reply
Display Modes
